Home > Forums > Software User Forums > SU2
Deforming 2D airfoil with text file DV_KIND= SURFACE_FILE
Old   March 1, 2017, 13:22
Default Deforming 2D airfoil with text file DV_KIND= SURFACE_FILE
nija parkman
newbie_cfd is on a distinguished road
I am trying to deform the airfoil boundary of a 2D mesh (naca0012 test/tutorial).
SU2 seems to have an option of deformation of DV_KIND= SURFACE_FILE with MOTION_FILENAME= mesh_motion_new.dat.
Running SU2_DEF without any dat file creates that file (as expected from the source code). This gives me the format, I then modify this file and rerun SU2_DEF, but no deformations occur.
What am I doing wrong there?
THanks,
nb
newbie_cfd is offline   Reply With Quote
Old   March 11, 2017, 04:40
hlk
Heather Kline
hlk is on a distinguished road
THanks,
nb
Thanks for your question
First, make sure that you are setting DV_MARKER
I'm not 100% sure, but MARKER_MOVING may also need to be set.
hlk is offline   Reply With Quote
Old   September 12, 2017, 06:34
Rocco
rocco.bom is on a distinguished road
Hi, my answer may be incomplete as I'm dealing with this problem myself at the moment.
Once you have your modified mesh_motion_new.dat file these are the following inpt you have to set to make everything work:
GRID_MOVEMENT = YES
GRID_MOVEMENT_KIND = DEFORMING / EXTERNAL % They both work for me
MARKER_MOVING= ( airfoil ) % or whatever you have set
DV_MARKER= ( airfoil )
Running SU2_DEF this way it performs a mesh deformation with the new prescribed boundary. (Double check your output)
Given that, I'd be interested in performing an unsteady simulation where the boundary deforms with a prescribed shape every timestep. But I haven't been able yet to find a closure to the problem. So, if you get anything new about it I would really appreciate if you can share your experience here! Thanks!
rocco.bom is offline   Reply With Quote
Thread Tools
Trackbacks are On
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 4 August 14, 2014 06:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
