Home > Forums > Software User Forums > SU2
Adjoint FFD Wing optimization convergence controllers
Old   November 15, 2019, 04:18
Default Adjoint FFD Wing optimization convergence controllers
Stanislav Karpuk
StanislavKarpuk is on a distinguished road
I have a little problem with setting the coefficients up for the wing optimization using FFD. Everything is working fine, but my adjoint solution takes way too long and converges to really small values I do not need. Can anybody tell me what parameters I need to change, so my convergence is stopped a bit earlier,
Last lines of the adjoint convergence
log10[Maximum residual]: -1.6298e+01.
Maximum residual point 1103, located at (-1.9286e+02, 3.8571e+02, -4.5000e+02).
Iter Time(s) Res[Psi_Rho] Res[Psi_E] Sens_Press Sens_AoA
2480 0.635330 -18.364197 -18.736024 -5.4461e-02 -2.4966e-03
2481 0.635222 -18.318372 -18.717016 -5.4461e-02 -2.4966e-03
2482 0.635114 -18.351926 -18.744432 -5.4461e-02 -2.4966e-03
2483 0.635005 -18.387036 -18.736493 -5.4461e-02 -2.4966e-03
2484 0.634907 -18.379428 -18.740495 -5.4461e-02 -2.4966e-03
2485 0.634804 -18.372618 -18.700524 -5.4461e-02 -2.4966e-03
2486 0.634697 -18.402309 -18.784623 -5.4461e-02 -2.4966e-03
2487 0.634589 -18.331247 -18.702867 -5.4461e-02 -2.4966e-03
2488 0.634481 -18.326309 -18.741878 -5.4461e-02 -2.4966e-03
2489 0.634376 -18.363654 -18.749159 -5.4461e-02 -2.4966e-03
2490 0.634268 -18.340797 -18.710770 -5.4461e-02 -2.4966e-03
2491 0.634163 -18.358591 -18.752570 -5.4461e-02 -2.4966e-03
2492 0.634058 -18.367746 -18.768742 -5.4461e-02 -2.4966e-03
2493 0.633951 -18.364933 -18.775686 -5.4461e-02 -2.4966e-03
2494 0.633843 -18.360979 -18.767785 -5.4461e-02 -2.4966e-03
2495 0.633736 -18.327877 -18.686616 -5.4461e-02 -2.4966e-03
2496 0.633629 -18.361588 -18.736146 -5.4461e-02 -2.4966e-03
2497 0.633522 -18.358536 -18.751150 -5.4461e-02 -2.4966e-03
2498 0.633415 -18.387406 -18.729346 -5.4461e-02 -2.4966e-03
2499 0.633308 -18.392014 -18.777462 -5.4461e-02 -2.4966e-03
-------------------------- File Output Summary --------------------------
Writing comma-separated values (CSV) surface files.
Loading solution output data locally on each rank.
Sorting output data across all ranks.
Writing binary SU2 native restart file.
2500 0.636858 -18.366780 -18.749547 -5.4461e-02 -2.4966e-03
2550 0.636943 -8.149034 -8.656327 -5.4453e-02 -2.4950e-03
2600 0.637018 -8.182186 -8.654305 -5.4360e-02 -2.4947e-03
2650 0.636950 -8.422885 -8.899310 -5.4400e-02 -2.4946e-03
2700 0.637045 -8.922409 -9.403217 -5.4422e-02 -2.4946e-03
2750 0.636958 -9.222539 -9.709249 -5.4410e-02 -2.4946e-03
2800 0.636749 -9.782752 -10.299221 -5.4415e-02 -2.4946e-03
2850 0.636529 -9.901253 -10.382556 -5.4415e-02 -2.4946e-03
2900 0.636331 -10.070406 -10.548106 -5.4414e-02 -2.4946e-03
2950 0.636126 -10.518349 -11.009703 -5.4415e-02 -2.4946e-03
Thank you,
Stan
StanislavKarpuk is offline   Reply With Quote
Continuity convergence issue on a 3d wing Nick R FLUENT 19 April 6, 2020 14:52
FFD box and wing section twist Marco_Vanderbijl SU2 Shape Design 0 May 17, 2019 16:46
Fluent Adjoint Solver Convergence Issue? ex10148 FLUENT 2 July 25, 2016 14:41
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Simple single element wing convergence Jonny6001 FLUENT 0 March 10, 2010 05:01
