The initialization of flow field for time accurate, unsteady simulation and BC |
March 28, 2013, 05:35 |
Jianguo
Rep Power: 14 |
Dear SU2 developers and users,
I wish to carry out the time accurate, unsteady simulation of an flow. I need to set up the simulation in SU2 and my questions are: 1. How can I implement the user-specified initial solution throughout the computational domain? The initial solution is the function of coordinates of mesh element. One possible way is to write the initial condition into the SU2 restart file using external program and following the SU2 restart file format. Then we carry out the calculation as a restart simulation. Is this correct? 2. I need to apply zero-gradient boundary condition. Is this type of boundary condition implemented in SU2? 3. Your AIAA paper indicates that the explicit R-K time integration scheme is included in SU2. Is this scheme developed by Jamson? Is the TVD R-K algorithm by Shu Chiwang used in your software? 4. For unsteady calculation, which limiter is better, Barth's limiter or Venk's algorithm? Thank you |
April 11, 2013, 13:38 |
Amrita Lonkar
Rep Power: 13 |
Hi Jianguo,
Yes, the way to implement a set of grid dependent initial condition is through the restart file. There are zero-gradient boundary conditions for some solvers such as the electric potential solver, there are adiabatic boundary conditions for zero temperature gradient at the walls. Can you please give us more detail about your equations and boundary conditions? The explicit R-K time integration scheme in SU2 is the Jameson implementation with division between convective and viscous terms. Venkatakrishnan limiter is generally more popular because it have a free parameter that allows convergence to machine precision. It is worth mentioning here that the limiter is only applied to the spatial discretization of the convective fluxes and NOT applied to the time discretization in SU2. Hope this helps, Amrita |
April 13, 2013, 14:15 |
#3 | |
Francisco Palacios
Rep Power: 15 |
solution_container[iZone][MESH_0][FLOW_SOL]->SetInitialCondition(geometry_container[iZone], solution_container[iZone], config_container[iZone], ExtIter); that you will find in the next developer version of the code (it will be available during the next week). Cheers, Francisco |
September 29, 2017, 15:38 |
#4 | |
Mehdi Mortazawy
Rep Power: 9 |
Thank you for your post! I am trying to simulate the complete 2D Shock Tube in SU2. Could you please help me understand how can I initialize the two zones of high and low pressure? Thank you very much in advance! Mehdi |
