Multi grid limitations for 3d cases and parallel run |
Rep Power: 9 ![]() |
Is there any limitations on using multigrid for 3d test cases or parallel run? , I am having a problem.When I run parallel code using mpirun -n 12 SU2_CFD (configname)
I get displayed only multigrid level 0,1,2 on console even when I choose multigrid as 3 in config file .If anyone faced this problem before or have a solution, please reply . Thanks in advance. ![]() |
Tim Albring
Rep Power: 11 ![]() |
SU2 stops the agglomeration of cells if no sufficient coarsening can be achieved any more. So there is an upper limit on the number of multigrid levels for each mesh which you apparently reached.
Tim
Developer Director @ SU2 Foundation Get involved:
Display Modes | |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
Some questions about a multi region case run in parallel | zfaraday | OpenFOAM Running, Solving & CFD | 5 | February 23, 2017 10:25 |
Unable to run parallel cases with OF 2.3.x in openSUSE 12.3 | zfaraday | OpenFOAM Running, Solving & CFD | 3 | February 2, 2015 20:42 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
Change parameter and run cases parallel | lingdeer | ANSYS | 0 | July 29, 2011 10:27 |
