-   SU2 (https://www.cfd-online.com/Forums/su2/)
-   -   Discrete Adjoint giving garbage values (https://www.cfd-online.com/Forums/su2/199305-discrete-adjoint-giving-garbage-values.html)
Manish Kumar Mishra March 3, 2018 08:25
I was previously using continuous adjoint solver for gradient computation. I decided to try Discrete Adjoint once but I am facing a problem here.
My direct simulation works, so I have a flow solution for the adjoint solver to use. I am also able to use the Continuous Adjoint solver to compute the gradient but when I tried running the Discrete Adjoint solver, it runs and residual values drop by 10 orders but the solution is way far off and when I check the adjoint variable contour, it seems terrible. With discrete Adj solver, the solution blows up!
I thought the problem was with my problem but I am facing the same problem with the config file and grid in QuickStart tutorial airfoil problem. Continuous adj works but not discrete adj.
I tried changing a few setting but I think those shouldn't make any difference. Has anyone faced this problem? Or if you can guess it and suggest a few things to try, I will be glad.
Thank you
Sprotte March 7, 2018 16:35
Assuming that your SU2_CFD_AD is fine and that you are reading in the solution file correctly - does changing the objective function change the behaviour?
Sounds a bit like a problem in that direction... :confused:
