Home > Forums > Software User Forums > SU2
separation prediction best practice
Old   March 30, 2020, 08:05
Default separation prediction best practice
tom pratt
tomp1993 is on a distinguished road
Hi everyone,
I'm just wondering is there a generally accepted 'best practice' way to set up a RANS case in SU2 specifically for capturing separation regions?
I have tried a couple of different grid topologies, Roe and JST schemes, SA and SST turbulence models, and a few other options in the config file. my case goes from M=0.15 to M=0.5 so incompressible isn't suitable. I'm not expecting amazing stall angle prediction but i would like to see roughly where the separation and attachment lines are.
unfortunately, so far either my solution doesn't converge (no force convergence) or converges on a solution which does not feature separation (when i definitely expect separation in reality).
on this note, are there any best practice methods for gridding this scenario too? i'm currently using a pointwise-generated hybrid grid with t-rex BL cells which have y+<2 and growth rate 1.2. with surface t-rex on the leading and trailing edges of the wing.
my geometry is a wing-body-tail half-span.
Unfortunately i cannot upload the case but this should be fine as i am asking for more general best practice advise.
Thanks in advance!
Tom
tomp1993 is offline   Reply With Quote
Turbulent Separation problem fluidmechanics FLUENT 1 September 7, 2015 13:59
wall function and flow separation O.D.Y. FLUENT 1 October 3, 2011 16:27
correct prediction with massive separation efb FLUENT 0 October 27, 2006 10:04
Separation prediction over a 2d cylinder.... Kyle FLUENT 2 December 9, 2005 04:17
Separation Prediction with Menters SST k-omega Jonas Larsson FLUENT 5 March 20, 2002 13:44
