July 9, 2018, 18:00 |
SU2 and slipstream effect
Bruno
Hi everyone,
I am currently working on an optimization of the NASA X-57 as a preliminary study and I am developing it with the use of SUAVE. However, I wanted to incorporate the aerodynamic results provided by SU2 into my SUAVE code. In order to do this firstly I would like to know if SU2 is capable of calculating the slipstream effect caused by propellers and its influence in the wing lift distribution? I need to know this since the X-57 has a lot of propellers and their main task is to increase the CLmax of the wing for the takeoff and landing. Thank you in advance for the feedback. Kind regards, Bruno |
September 29, 2018, 13:23 |
#2 | |
Heather Kline
Rep Power: 13 |
Thank you for your question.
SU2 has an actuator disk option that is meant to simulate engines in a simple way by adding a jump in flow quantities. This is likely the closest to what you are looking for that is currently implemented. For an example, see: TestCases/rans/propeller/propeller.cfg And there are also some additional engine related options in the config_tempalte files that may help. Quote:
optimization, propellers, slipstream, x-57 |
Display Modes | |
