Urgent - Perform an DISCRETE adjoint analysis in parallel_computation |
April 15, 2018, 12:12 |
João Lourenço
Rep Power: 9 |
Hello everyone,
I'm with some problems in performing a Discrete Adjoint analysis in parallel computation using the solution_flow file from the direct analysis to the flow. I'm doing the some proceeder like in CONTINUOUS Adjoint analysis. In CONTINUOUS adjoint I'm doing the next steps: 1- Run the mesh.su2 and the NACA_0012.cfg file with: MATH_PROBLEM= DIRECT RESTART_SOL= NO terminal: parallel_computation.py -f NACA_0012.cfg -n 8 2- Change the name of restart_flow.dat to solution_flow.dat 3- Change in the NACA_0012.cfg file MATH_PROBLEM= CONTINUOUS_ADJOINT RESTART_SOL= NO 4- Run the mesh.su2, NACA_0012.cfg and solution_flow.dat file. terminal: parallel_computation.py -f NACA_0012.cfg -n 8 in the terminal the parallel analysis identify the solution_flow.dat and mesh.su2 to performed the adjoint analysis. For the DISCRETE adjoint analysis I follow the same steps but, in the terminal, appears only identified the mesh file and says "No restart solution, use the values at infinity (freestream).". How can I perform an DISCRETE_ADJOINT analysis in parallel with the solution_flow.dat file? My goal is to do an shape optimization with the solution_flow.dat and the solution_adj.dat file. Thanks to everyone that help me |
April 23, 2018, 10:38 |
Tim Albring
Rep Power: 10 |
Just follow exactly the same steps, but with MATH_PROBLEM=DISCRETE_ADJOINT instead of MATH_PROBLEM=CONTINUOUS_ADJOINT.
Or just execute the discrete_adjoint.py script. Tim
Developer Director @ SU2 Foundation Get involved:
Problems launching adjoint | max_ | SU2 | 2 | March 12, 2016 11:32 |
hard to convergent with SU2 4.0 for Euler adjoint | Xianguu | SU2 | 1 | July 14, 2015 17:09 |
Flow analysis in a Convergent-Divergent Nozzle (URGENT!) | hasan_hzl | ANSYS | 2 | June 30, 2009 00:46 |
Urgent help needed with dpm analysis | Esosa | FLUENT | 0 | June 12, 2009 05:06 |
Problem about multi-phase analysis (Urgent) | Prof. Lau (PolyU) | CFX | 2 | February 9, 2007 17:59 |
