June 18, 2018, 04:30 |
Problem with Discrete adjoint based on RANS
Suman Vajjala
Rep Power: 11 |
Hi. I am using SU v 6.1 to extract adjoints for a simple onera M6 wing (mesh provided in the SU2 Testcases suite) using discrete adjoint for RANS and the simulations are blowing-up when the solver starts the AD part after I get the direct solution. However, the same simulation does not blow when running Euler simulation instead of RANS. I have tried many options- reducing CFL no, changing the flux calculation (Least squares and Green-Gauss) but none worked. Can you please suggest what to do in this regard.
Best Suman |
July 4, 2018, 03:36 |
Zeno
Rep Power: 12 |
Hi Suman,
Can you attach your config file? Zen |
July 12, 2018, 01:37 |
Suman Vajjala
Rep Power: 11 |
Hi Zen!
Sorry for the late reply. I have attached the config file. Please let me know if there are any issues with it. Thanks Suman |
July 31, 2018, 05:36 |
Pedro Gomes
Hi Suman,
The universal advise with discrete adjoint is that you should converge the direct solver very well. Do note that the turbulence residuals usually take longer to drop, I usually use a much larger CFL for the turbulence equations (by setting CFL_REDUCTION_TURB > 1). With regards to solver settings you can try: MGLEVEL= 2 or 3 LINEAR_SOLVER= BCGSTAB LINEAR_SOLVER_PREC= ILU LINEAR_SOLVER_ERROR= 1E-3 LINEAR_SOLVER_ITER= 1000 (just to make sure the linear solver converges) DISCADJ_LIN_SOLVER= BCGSTAB DISCADJ_LIN_PREC= ILU I suggest the switch to BiCGSTAB because that way you can increase the number of iterations to make sure the linear solver converges during the first iterations without increasing memory usage (that would happen with FGMRES). If BiCGSTAB fails (it should not with the CFL you have) switch back to FGMRES, keep ILU and reduce the number of iterations to the 10-100 range. You mentioned that Euler works fine, keep in mind that SU2 does not have wall functions, therefore you need y+ around 1. If your wall cell size is already that small be careful with very high edge ratios (1000:1 is as far as I would go for testing). If all this fails there is always the option to freeze the turbulence in the adjoint solver (I do not recall the name but you can check the template config file). Cheers, Pedro |
su2 ad |
the gradients calculated through discrete adjoint are near zero | Haowang | SU2 | 9 | October 17, 2019 22:53 |
SU2 LES, discrete adjoint | testcase | SU2 | 1 | July 27, 2017 04:46 |
Problem with Application based on a faceZone in parallel | psilkeit | OpenFOAM Programming & Development | 2 | April 28, 2016 09:47 |
SQP method for adjoint based aerodynamic shape optimization | cfdbooks | Main CFD Forum | 2 | May 26, 2009 10:40 |
steady RANS for flow problem with unsteady inlet? | kat | Main CFD Forum | 0 | February 16, 2009 10:24 |
