Eugene Sharaborin
Rep Power: 0 ![]() |
Hello, dear SU2 lovers!
I would like to implement my own model of resin flow through the fiber reinforcement matrix. So there will be: 1) Navier-Stokes equations (mass, momentum, energy conservations) with specific source terms 2) mass conservation for each species 3) my own equation of state 4) adding divergent terms which take into consideration surface tension I saw input *.cfg files and understood that I can't add my own equations/terms into an equation. How I understood I need to change {numerics, solver, variable}_template.cpp files in SU2_CFD/src/, is it right? Is there any tutorial on how to change correctly these files? |
my own module, navier-stokes |
Display Modes | |
[foam-extend.org] Module file foam-extend 3.2 CentOS cluster | KarthickRajkumar | OpenFOAM Installation | 2 | March 26, 2017 13:52 |
Testing the LES module coupled with the dbnsTurbFoam solver | sathya123 | OpenFOAM Running, Solving & CFD | 6 | August 7, 2016 17:06 |
Conduction and Convection Thermal Analysis of a PV Module | firestone9x | ANSYS | 0 | February 19, 2016 08:26 |
[snappyHexMesh] Debug option in snappy / Write volScalarField with cellLevel for postprocessing | Ruli | OpenFOAM Meshing & Mesh Conversion | 1 | March 30, 2014 08:57 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
