Home > Forums > Software User Forums > SU2
V6.1.0 Optimization problem
Old   December 17, 2018, 07:01
Default V6.1.0 Optimization problem
JAMES
yugang881 is on a distinguished road
Dear friends:
when i use V6.1.0 running the "Constrained Optimal Shape Design of a Fixed Wing" sample, there is always an error occures as "No such file or directory: history_direct.dat". But i use V5.0.0 there is no problem. And this file is also not exist in the test case files. Could anyone give some suggestion? Thanks!
yugang881 is offline   Reply With Quote
Old   December 17, 2018, 07:04
JAMES
The 3 files need for restart solution are the solution_adj_cd.dat, solution_adj_cl.dat, solution_flow.dat. I think there is no need for history_direct.dat.
Heat Transfert, mixing problem Wazdq CFX 8 November 7, 2016 06:44
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Parametric runs and Optimization in ANSYS (Conjugate Heat Transfer Problem) cp_jef ANSYS 0 May 30, 2011 05:08
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
