restart_flow.dat filesize resets during parallel run |
February 27, 2019, 05:45 |
merijn
im trying to get paralel run to work,
i observe the file restart_flow.dat gets filled with data to 735841 bytes and then it resets to 231 bytes multiple times during the run. is this expected behavour? any insight or tips would be apreciated. merijn |
May 10, 2019, 10:12 |
Wally Maier
Rep Power: 7 |
Hi Merijn,
Thanks for reaching out and using SU2! This does seems to be a strange issue. Were your results correct? Or were they depreciated? If you send me your config file, I can take a look. My guess is something with your local machine and parallel is a bit wonky. However, if your solution is correct, my guess is the code is working properly. Let me know if you continue to have problems. Wally |
The problem when i use parallel computation for mesh deforming. | Hiroaki Sumikawa | OpenFOAM Running, Solving & CFD | 0 | November 20, 2018 02:58 |
User fortran to input/output file in a parallel run | doublestrong | CFX | 5 | March 31, 2017 08:15 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
