Home > Forums > Software User Forums > SU2
Thickness constraint SU2 AIAA ADODG Benchmark Case 1
Old   March 28, 2019, 01:15
Default Thickness constraint SU2 AIAA ADODG Benchmark Case 1
cfdjetman
cfdjetman is on a distinguished road
How do I specify the following thickness constraint in SU2
y>= 0.6(0.2969*sqrt(x)0.1260*x0.3516*x^2+ 0.2843*x^30.1036*x^4)
x is the cord position along the airfoil.
This is NACA 0012 airfoil.
cfdjetman is offline   Reply With Quote
Old   October 9, 2019, 08:32
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Any progress to this thread?
atelcikti1 is offline   Reply With Quote
Old   October 9, 2019, 09:14
atelcikti1's Avatar
Or simply, where do I place my own code to define geometric constraints. Is there any template class for this purpose or I have to also change python scripts? Any advice will be appreciated.
Old   October 14, 2019, 15:46
cfdjetman
Check this paper
https://www.researchgate.net/publica...lems_Using_SU2.
Old   October 15, 2019, 08:00
atelcikti1's Avatar
Originally Posted by cfdjetman View Post
Actually I have read the paper, but its not seem to relevant to my case. In paper, they use airfoil max. thickness as constraint. I have to define number of stations and I want to give min max values for each station on airfoil or simply any wall line.
Old   October 15, 2019, 14:40
cfdjetman
I simulated only the upper half of the airfoil as the case is symmetric. I generated FFD control points on the upper half of the airfoil. I set the lower bounds for these control points to 0. That way, it is constrained to move only in the positive Y direction (upwards in this case). This way the baseline shape is not violated. My simulations have worked well.
Note: BFGS cannot handle bounds and constraints. SLSQP can.
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Trying to run a benchmark case with simpleFoam spsb OpenFOAM 3 February 24, 2012 10:07
3D benchmark case in spherical coordinate merryfish Main CFD Forum 0 June 24, 2009 21:15
benchmark test case for MHD RT instability cou Main CFD Forum 0 May 7, 2007 10:38
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
