Home > Forums > Software User Forums > SU2
Tag an internal marker in SU2
Like Tree1Likes
  • 1 Post By akshaydeshpande
Old   August 28, 2019, 10:00
Default Tag an internal marker in SU2
Akshay Deshpande
akshaydeshpande is on a distinguished road
Hi all,
Is it possible to tag an internal marker (MARKER_INTERNAL) lying within a domain? I am trying to extract data at internal points during an unsteady simulation, and was planing to follow the template set by the function SetSurfaceCSV_Flow in output_structure.cpp.
The .su2 mesh file includes information only on the boundary markers (NMARK=6 for a 3D problem). Therefore I cannot loop over the vertices of any internal surface to extract data. Any advice would be appreciated.
Thanks,
Akshay
ugurtan666 likes this.
akshaydeshpande is offline   Reply With Quote
Old   September 2, 2019, 13:28
Default Probably you can
Aman uz zaman Baig
aman_baig is on a distinguished road
I haven't used MARKER_INTERNAL for this purpose yet, but I believe this is what it is supposed to do. The nodes on this marker are ignored during the computation, so it must be possible to extract node data by specifying in MARKER_PLOTTING the same marker. Let me know if this works for you.
aman_baig is offline   Reply With Quote
data extraction, internal markers, su2
Mesh Nastran for Su2 translator - 0 boundary elements in index 0 (Marker = ). fabio_ SU2 1 May 16, 2019 15:21
CGNS Boundary conditions using SU2 denzell SU2 3 July 9, 2018 05:58
SU2 Marker error for 3D CGNS mesh McAero SU2 4 November 9, 2017 13:54
Nondimensional run marco.fossati SU2 0 November 29, 2016 14:38
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 22:38
