May 13, 2019, 07:37 |
SU2 v6.0.0
Karim
Rep Power: 6 |
I have installed SU2 v6.0.0 on my windows7 computer. I'm trying to do the tutorial examples but in most cases I get Config_Parsing errors such for the INC_Density_INIT , INC_Velocity_INIT, CONV_NUM_METHOD_FLOW... Are those errors related to the fact that windows uses SU2 V6.0.0 and the tutorial configs are for 6.0.2 ? If so is there a repository with 6.0.0 tutorials ? Kind Regards Karim |
May 13, 2019, 10:39 |
Wally Maier
Rep Power: 7 |
Hi Karim,
Thanks for reaching out! There shouldn't be an issue between v6.0.0 and v6.0.2 config files. CONV_NUM_SCHEME_FLOW is still used. Could you post your config file so we can take a more detailed look? Thanks and Good luck, Wally |
May 13, 2019, 12:20 |
#3 | |
Karim
Rep Power: 6 |
Many thanks for your prompt reply. I'm using the unmodified lam_backwardstep.cfg and corresponding mesh from the Laminar backstep tutorial. (https://su2code.github.io/tutorials/Inc_Laminar_Step/). I'm running it with the sequential binary executable version of SU2 on my window 7 PC. See the attached picture for the error I am getting. Kind Regards, Karim |
May 13, 2019, 12:33 |
Wally Maier
Rep Power: 7 |
Hi Karim,
I took a look quickly, and i think your original thought was correct. I believe the config file you are using is for a more updated version of SU2 (v6.2?). You can check the config_template.cfg : https://github.com/su2code/SU2/blob/...g_template.cfg. If you go to the tutorials page: https://github.com/su2code/su2code.g...io/tree/v6.0.0 you can see the available cases you can run. If you wish to switch the version of SU2 files, you can use the drop down message (i think it is initially branches) and change the "Tag" to whichever version you would like to see. Please let me know if I can help anymore! Wally |
May 13, 2019, 12:56 |
#5 | |
Karim
Rep Power: 6 |
Best Karim |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 22:38 |
SU2 v6.0.0 windows zip - Installer Application? | Harry_D | SU2 Installation | 1 | February 20, 2018 14:20 |
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 02:40 |
Official release of SU2 V3.0 and SU2 Educational V1.0 | fpalacios | SU2 News & Announcements | 2 | January 22, 2014 05:28 |
Welcome to the Stanford University Unstructured (SU2) forum! | economon | SU2 | 0 | January 7, 2013 02:48 |
