-   SU2 (https://www.cfd-online.com/Forums/su2/)
-   -   Customized inlet profile for Turbomachinery (MARKER_GILES) (https://www.cfd-online.com/Forums/su2/219248-customized-inlet-profile-turbomachinery-marker_giles.html)
aman_baig July 21, 2019 19:14
2 Attachment(s)
I know we can define a customized inlet profile using
SPECIFIED_INLET_PROFILE = YES,
and that would work as an alternative to,
MARKER_INLET = ().
But for TurboMachinery applications, we have MARKER_GILES, such that:
MARKER_GILES= (inflow, TOTAL_CONDITIONS_PT, 169623.33, 305.76,, 1.0, 0.0, 0.0,1.0,1.0, outmix, MIXING_OUT, 0.0, 0.0, 0.0, 0.0, 0.0,1.0,1.0, inmix, MIXING_IN, 0.0, 0.0, 0.0, 0.0, 0.0,1.0, 1.0 outflow, STATIC_PRESSURE, 99741.00, 0.0, 0.0, 0.0, 0.0,1.0,1.0)
In this case, if I use SPECIFIED_INLET_PROFILE = YES then it will output a sample inlet_example.dat file with NMARK = 0. So I tried this out:
MARKER_INLET=(inflow, 305.76, 169623.33,, 1.0, 0.0, 0.0)
MARKER_GILES= (outmix, MIXING_OUT, 0.0, 0.0, 0.0, 0.0, 0.0,1.0,1.0, inmix, MIXING_IN, 0.0, 0.0, 0.0, 0.0, 0.0,1.0, 1.0 outflow, STATIC_PRESSURE, 99741.00, 0.0, 0.0, 0.0, 0.0,1.0,1.0)
This does output a valid inlet_example.dat file but that is not read by SU2 when I give that name in INLET_FILENAME. I don't know how to resolve it.
If someone can suggest something that would be helpful. I want to accommodate a distortion in the inlet profile.
Mesh for the attached config file: https://github.com/su2code/TestCases...l_stage_2D.su2
EDIT:
Surprisingly the same configuration works for a single row case. This must be a SU2 bug.
Single row (mesh):
https://github.com/su2code/TestCases...u2mesh_per.su2
Thanks.
