Config file: "FREESTREAM_TURBULENCEINTENSITY" in % or ratio |
January 23, 2019, 05:40 |
jayten
I am using the SST model in SU2 for computation of turbulent flow over a flat plate. The free-stream turbulence intensity of the fluid-flow I am computing is 3%. In the config.cfg file, whether I have to provide the free-stream value of turbulence intensity ("FREESTREAM_TURBULENCEINTENSITY") as 0.03 or 3.0?
July 22, 2019, 12:16 |
Vishal
If you check transition plate tutorial on SU2 website it shows 0.18% turbulent intensity to be entered as 0.18.
https://su2code.github.io/tutorials/...al_Flat_Plate/ But if you check the value of Turb. Kin. Energy when you run the simulation it will use 0.18 in following equation. (Turb. Kin. Energy = 3/2 (U I)^2). I feel considering I = 0.18% it should be entered as 0.0018. It will be great if someone else can confirm about this confusion. |
August 4, 2019, 06:02 |
#3 | |
Tim Albring
Rep Power: 10 |
Developer Director @ SU2 Foundation Get involved:
config files, turbulence intensity |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
