-   SU2 (https://www.cfd-online.com/Forums/su2/)
-   -   Parallelizing SU2 in PBS (https://www.cfd-online.com/Forums/su2/219490-parallelizing-su2-pbs.html)
NKever July 29, 2019 10:06
I am trying to run the shape_optimization.py script and use all my available nodes in PBS and I don't think I am doing this right.
Here is my script:
#PBS -q devel
##PBS -q long
##PBS -q normal
#PBS -W group_list=a1489
#PBS -lselect=50:ncpus=28:model=bro,walltime=02:00:00
##PBS -lselect=80:ncpus=28:model=bro,walltime=08:00:00
##PBS -lselect=80:ncpus=28:model=bro,walltime=50:00:00
#PBS -N test_su2
# Request that regular output and terminal output go to the same file
#PBS -j oe
#PBS -m n
# go to where the qsub was performed.
cd $PBS_O_WORKDIR
# Running Program
export SU2_RUN="/home6/nkever/su2/install/SU2/bin"
export SU2_HOME="/home6/nkever/su2/src/SU2"
export PATH=$PATH:$SU2_RUN
export PYTHONPATH=$PYTHONPATH:$SU2_RUN
module load mpi-sgi/mpt
module load python/2.7.15
module load comp-intel/2018.0.128
./shape_optimization.py -g CONTINUOUS_ADJOINT -o SLSQP -f inv_NACA0012_basic.cfg -n 400
echo "finished mpirun"
So I think the issue may be the -n, my interpretation is that the number of partitions tells su2 the amount of nodes. How do I use all my nodes?
I've seen this thread already, but I'm not sure it addresses my question. Thank you!
jayantmukho August 8, 2019 16:39
Hey Nadeem,
Is your issue that PBS doesn't use the different nodes and just tries to start all 400 processes on 1 node?
I had this particular issue when I was trying to run using openmpi with PBS. In that case, the openmpi installation that I was using wasn't configured to work with torque/pbs (https://www.open-mpi.org/faq/?category=tm). It required a particular option to be set when configuring openmpi.
I haven't used SGI MPT before so I am not certain if there is a similar issue that would need to be rectified.
pcg August 25, 2019 05:42
Hi Nadeem,
The problem might be that all nodes are executing the shape optimization script, and only one should since it is not an mpi-ready program (I think).
The simplest way to do this kind of thing would be to wrap the SU2 execution in a script that submits an individual job per SU2 run and waits for results.
Cheers,
Pedro
