-   SU2 (https://www.cfd-online.com/Forums/su2/)
-   -   the simulation of Backward facing step (https://www.cfd-online.com/Forums/su2/219568-simulation-backward-facing-step.html)
liujmljm July 31, 2019 15:23
Hello, sorry I re-post the problem again.
recently I try to use SU2-6.2.0 to run a case (3d backward facing step). I used both of DDES and RANS. But both of them will divergent after some time steps and break down. The grid is obtained from https://turbmodels.larc.nasa.gov/backstep_grids.html. I choose a small cgns grid (2x65x65, 2x25x65, 2x97x113, 2x33x113 ) to generate a 3d grid in the format of SU2. In the spanwise direction, the length is 3 times of step height with 40 grids.
I paste the cfg file here and the used grid. Is there any people has succeed in this simulation.
Thank u very much.
the grid can be downloaded from
https://www.dropbox.com/s/xyk8ownh9c...Jul23.su2?dl=0
% SU2 configuration file %
% Case description: Turbulent flow around a square cylinder %
% Author: Thomas D. Economon %
% Institution: Stanford University %
% Date: 2013.02.25 %
% File Version 6.2.0 "Falcon" %
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
PHYSICAL_PROBLEM= NAVIER_STOKES
% If Navier-Stokes, kind of turbulent model (NONE, SA)
KIND_TURB_MODEL= SA
HYBRID_RANSLES= SA_DDES
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT)
MATH_PROBLEM= DIRECT
% Restart solution (NO, YES)
RESTART_SOL= NO
% Write binary restart files (YES, NO)
WRT_BINARY_RESTART= NO
% Read binary restart files (YES, NO)
READ_BINARY_RESTART= NO
% Unsteady restart iteration (need previous restart files)
UNST_RESTART_ITER=2
% ------------------------- UNSTEADY SIMULATION -------------------------------%
% Unsteady simulation (NO, TIME_STEPPING, DUAL_TIME_STEPPING-1ST_ORDER,
% DUAL_TIME_STEPPING-2ND_ORDER, HARMONIC_BALANCE)
UNSTEADY_SIMULATION= DUAL_TIME_STEPPING-2ND_ORDER
% Time Step for dual time stepping simulations (s)
UNST_TIMESTEP= 0.00005
% Total Physical Time for dual time stepping simulations (s)
UNST_TIME= 7.5
%UNST_TIME= 0.001
% 2500 iterations - 3.75
% 3500 iterations - 5.25
% 5000 iterations - 7.50
% Number of internal iterations (dual time method)
UNST_INT_ITER=15
% ----------- COMPRESSIBLE AND INCOMPRESSIBLE FREE-STREAM DEFINITION ----------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 0.2
% Angle of attack (degrees)
AOA= 0.0
% Side-slip angle (degrees)
SIDESLIP_ANGLE= 0.0
% Free-stream temperature (288.15 K by default)
FREESTREAM_TEMPERATURE= 300.0
% Reynolds number (non-dimensional, based on the free-stream values)
REYNOLDS_NUMBER= 36000.0
% Reynolds length (in meters)
REYNOLDS_LENGTH= 1.0
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
% Reference origin for moment computation
REF_ORIGIN_MOMENT_X = 0.00
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = 0.00
% Reference length for pitching, rolling, and yawing non-dimensional moment
REF_LENGTH= 1.0
% Reference area for force coefficients (0 implies automatic calculation)
REF_AREA= 1.0
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes wall boundary marker(s) (NONE = no marker)
MARKER_HEATFLUX= ( topwall, 0.0,lowerwall,0.0 )
MARKER_PERIODIC= ( cebianB, cebianA, 0,0,0, 0,0,0, 0,1.0,0.0)
% Farfield boundary marker(s) (NONE = no marker)
%MARKER_FAR= ( top )
% Marker(s) of the surface to be plotted or designed
MARKER_PLOTTING= ( lowerwall )
% Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= ( lowerwall )
% Inlet boundary marker(s) (NONE = no marker)
% Format: ( inlet marker, total temperature, total pressure, flow_direction_x,
% flow_direction_y, flow_direction_z, ... )
MARKER_INLET= ( inflow, 302.4, 118309.784, 1.0, 0.0, 0.0 )
% Outlet boundary marker(s) (NONE = no marker)
% Format: ( outlet marker, back pressure, ... )
MARKER_OUTLET= ( outflow, 115056.0 )
% Symmetry boundary marker(s) (NONE = no marker)
%MARKER_SYM= (topsym,lowersym,cebianB, cebianA, )
MARKER_SYM= (topsym,lowersym )
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, LEAST_SQUARES,
% WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 2.0
% Adaptive CFL number (NO, YES)
CFL_ADAPT= NO
% Parameters of the adaptive CFL number (factor down, factor up, CFL min value,
% CFL max value )
CFL_ADAPT_PARAM= ( 1.5, 0.5, 1.0, 100.0 )
% Runge-Kutta alpha coefficients
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% Number of total iterations
EXT_ITER= 30010
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
% Linear solver for the implicit (or discrete adjoint) formulation (BCGSTAB, FGMRES)
LINEAR_SOLVER= FGMRES
% Preconditioner of the Krylov linear solver (JACOBI, LINELET, LU_SGS)
LINEAR_SOLVER_PREC= LU_SGS
% Min error of the linear solver for the implicit formulation
LINEAR_SOLVER_ERROR= 1E-6
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 10
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 0
% Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE)
MGCYCLE= V_CYCLE
% Multi-grid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multi-grid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 0.7
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 0.7
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= ROE
% Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER)
MUSCL_FLOW= YES
% Coefficient for the limiter
VENKAT_LIMITER_COEFF= 5.0
% 2nd and 4th order artificial dissipation coefficients
JST_SENSOR_COEFF= ( 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
%TIME_DISCRE_FLOW= EULER_EXPLICIT
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations.
% Required for 2nd order upwind schemes (NO, YES)
MUSCL_TURB= NO
% Slope limiter (NONE, VENKATAKRISHNAN, BARTH)
SLOPE_LIMITER_TURB= VENKATAKRISHNAN
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_CRITERIA= RESIDUAL
% Residual reduction (order of magnitude with respect to the initial value)
RESIDUAL_REDUCTION= 3
% Min value of the residual (log10 of the residual)
RESIDUAL_MINVAL= -10
% Start convergence criteria at iteration number
STARTCONV_ITER= 10
% Number of elements to apply the criteria
CAUCHY_ELEMS= 100
% Epsilon to control the series convergence
CAUCHY_EPS= 1E-5
% Function to apply the criteria (LIFT, DRAG, NEARFIELD_PRESS, SENS_GEOMETRY,
% SENS_MACH, DELTA_LIFT, DELTA_DRAG)
CAUCHY_FUNC_FLOW= DRAG
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
%MESH_FILENAME= mesh_square_turb_hybrid.su2
%MESH_FILENAME= bkstpsm.su2
MESH_FILENAME=bkstpJul23.su2
% Mesh input file format (SU2, CGNS NETCDF_ASCII)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
%SOLUTION_FLOW_FILENAME= solution_flow.dat
SOLUTION_FLOW_FILENAME= restart_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
% Output file format (PARAVIEW, TECPLOT)
OUTPUT_FORMAT= TECPLOT
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FLOW_FILENAME= restart_flow.dat
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file flow (w/o extension) variables
VOLUME_FLOW_FILENAME= flow
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output Objective function gradient (using continuous adjoint)
WRT_CSV_SOL=NO
%WRT_SURF_FREQ_DUALTIME=100
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FLOW_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Writing solution file frequency
WRT_SOL_FREQ= 400
% Writing solution file frequency for physical time steps (dual time)
WRT_SOL_FREQ_DUALTIME= 200
WRT_SURF_FREQ_DUALTIME= 200
% Writing convergence history frequency
WRT_CON_FREQ= 1
% Writing convergence history frequency (dual time, only written to screen)
WRT_CON_FREQ_DUALTIME= 1
