Thickness constraint SU2 AIAA ADODG Benchmark Case 1 |
March 28, 2019, 00:15 |
cfdjetman
Rep Power: 7 |
How do I specify the following thickness constraint in SU2
y>= 0.6(0.2969*sqrt(x)−0.1260*x−0.3516*x^2+ 0.2843*x^3−0.1036*x^4) x is the cord position along the airfoil. This is NACA 0012 airfoil. |
October 9, 2019, 07:32 |
Rep Power: 9 |
Any progress to this thread?
October 9, 2019, 08:14 |
Rep Power: 9 |
October 14, 2019, 14:46 |
cfdjetman
Rep Power: 7 |
October 15, 2019, 07:00 |
#5 | |
Rep Power: 9 |
Actually I have read the paper, but its not seem to relevant to my case. In paper, they use airfoil max. thickness as constraint. I have to define number of stations and I want to give min max values for each station on airfoil or simply any wall line. |
October 15, 2019, 13:40 |
cfdjetman
Rep Power: 7 |
I simulated only the upper half of the airfoil as the case is symmetric. I generated FFD control points on the upper half of the airfoil. I set the lower bounds for these control points to 0. That way, it is constrained to move only in the positive Y direction (upwards in this case). This way the baseline shape is not violated. My simulations have worked well.
Note: BFGS cannot handle bounds and constraints. SLSQP can. |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 09:07 |
3D benchmark case in spherical coordinate | merryfish | Main CFD Forum | 0 | June 24, 2009 20:15 |
benchmark test case for MHD RT instability | cou | Main CFD Forum | 0 | May 7, 2007 09:38 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
