Home > Forums > Software User Forums > SU2
Restart run with different AOA
Old   October 26, 2019, 22:53
Default Restart run with different AOA
Hyun Ko
hyunko is on a distinguished road
Hi everyone.
I am using SU2 to simulate flight vehicle with different altitude, mach, aoa, aoss.
Now I have completed the simulation for one particular case. Such as aoa=0, aoss=0. (case0)
I want to use case0 as an initial condition for next run.
I am trying the solution of case0 as a restart file, and change cfg file with different aoa.
Then, Does SU2 reflect the boundary conditions correctly as I want?
Thanks in advance.
hyunko is offline   Reply With Quote
Old   October 27, 2019, 04:49
Amit
aero_amit is on a distinguished road
It is likely to work and you may save some computational efforts. You already may be doing this - copy restart_flow.dat to solution_flow.dat than use
RESTART_SOL= YES in the cfg file. Change AOA and SIDESLIP_ANGLE and run it.
Solution will start changing from the boundaries to interior over the iterations.
Share the advantage you obtain by using a different aoa initial solution.
aero_amit is offline   Reply With Quote
Old   October 27, 2019, 06:06
pcg
Pedro Gomes
pcg is on a distinguished road
Hi Hyun,
It depends on the version, I think there is a bug in v6.2 that causes the angle of attack to be read from the restart file.
I just tested with the current develop branch (soon to be v7.0) and that issue seems to have been solved.
If you are unsure whether the solver is taking your inputs correctly just compare the residuals on the last iteration before the restart file is created and on the first iteration of your new run, the residuals should be very different.
Cheers,
Pedro
pcg is offline   Reply With Quote
Old   October 27, 2019, 06:07
Amit
Originally Posted by pcg View Post
Hi Hyun,
Cheers,
Pedro
I was not aware of this bug. Great.
Old   October 27, 2019, 06:14
Hyun Ko
Hi Hyun,
Cheers,
Pedro
Thank you for your answer.
I am using 6.2 and think some bug on restart run with different Bc.
I will wait until v7.0 and run the simulation without restart run.
Thanks
Old   November 4, 2019, 12:06
Hyun Ko
Following input statement may solve this problem in v6.2.
DISCARD_INFILES= YES
Additionally, plz read this. Will help.
Modification of a cfg parameter in restart
I’m not tested yet. Back after testing.
cannot run naca0012 case using JST paulocaveman SU2 0 December 26, 2016 01:08
Restart to adjoint for Unsteady Turbulence Cylinder flow yweng3 SU2 0 October 7, 2016 14:50
Restart run of dsmcFoam from nonzero time mechy OpenFOAM Running, Solving & CFD 2 April 28, 2016 02:24
Restart FSI run on ANSYS CFX lingdeer CFX 3 October 10, 2011 09:47
Restart Residual diegon OpenFOAM Running, Solving & CFD 0 December 6, 2006 08:34
