January 28, 2020, 03:56 |
Unsteady Conjugate heat transfer
Oren Peles
Rep Power: 6 |
Hey
is there an example for unsteady conjugate heat transfer in SU2? I'm trying to modify the test case with the flow around three heated cylinders to an unsteady problem and it doesn't works. |
January 28, 2020, 09:22 |
Pedro Gomes
Rep Power: 13 |
Try the develop branch, some bugs have recently been addressed an new testcases added:
https://github.com/su2code/SU2/pull/839 |
January 28, 2020, 09:43 |
Ole Burghardt
Rep Power: 10 |
Hi there,
I've modified those test cases myself some time ago and got some nice results (heatfluxes oscillating with the 'right' frequency, also the videos have not been looking too bad ). Though I'd have to search for them and see whether they required some modifications in the code. I'll come back to this the next couple of days. Best, Ole |
January 29, 2020, 08:24 |
#4 | |
Ole Burghardt
Rep Power: 10 |
They do, but just a very minor one to set the same physical time step in all zones which has no proper solution in the (new) multizone framework so far. So I just hacked it in some time ago and it still works fine. I'll open up a work-in-progress pull request on github as soon as I have the results ready so that we can agree on a fix for that. (Together with the adapted test case so that you can check yourself.) Thanks for pointing us there. Ole |
January 29, 2020, 08:45 |
Ole Burghardt
Rep Power: 10 |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 03:07 |
Conjugate Heat Transfer | Gowrav | FLUENT | 0 | October 10, 2018 05:55 |
No conjugate heat transfer between solid (cast iron) and fluid (water) | Rajaero | Main CFD Forum | 1 | August 23, 2018 13:01 |
Unsteady conjugate heat transfer Negative initial temperature T0: -3918.142 | Cagatayemre | OpenFOAM Running, Solving & CFD | 4 | January 10, 2018 17:20 |
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
