Home > Forums > Software User Forums > SU2
How to output the pitching moments ?
Like Tree1Likes
  • 1 Post By cfdjetman
Old   February 4, 2020, 19:43
Default How to output the pitching moments ?
boling yang
boling2002 is on a distinguished road
I tried to output the pitching moment for the M6 wing, but it is always ignored by the solver. How can I turned it on ?
Thanks
% Screen output fields
SCREEN_OUTPUT = (INNER_ITER, RMS_DENSITY, RMS_NU_TILDE, LIFT, MOMENT-Y, DRAG)
boling2002 is offline   Reply With Quote
Old   February 5, 2020, 03:56
Tim Albring
talbring is on a distinguished road
there seems to be a typo in the documentation and/or the code. The fields for the moments are called MOMENT_X, MOMENT_Y, MOMENT_Z
It is a little bit inconsistent with the rest of the fields and we might change that soon.
Thanks for the question!
Developer Director @ SU2 Foundation
Get involved:
talbring is offline   Reply With Quote
Old   February 5, 2020, 10:49
boling yang
Thank you, and it works
Originally Posted by talbring View Post
Old   February 5, 2020, 11:55
Tim Albring
Glad that it works. You can also use SU2_CFD -d <your_configfile> to get a list of all possible output fields (at least with v7.0.0, in v7.0.1 there is a small bug, which will be fixed in the next maintenance release)
Get involved:
Old   February 5, 2020, 16:51
cfdjetman
cfdjetman is on a distinguished road
How do I print out the adjoint results such as sensitivity etc. in both the history and surface files in SU2 v7? I managed to get the flow results. However, when I use the command SU2_CFD -d config.cfg file, I do not see how to print out the adjoint related results.
Thanks
cfdjetman is offline   Reply With Quote
Old   February 6, 2020, 10:50
Tim Albring
Hi cfdjetman,
you have to set MATH_PROBLEM to DISCRETE_ADJOINT or CONTINUOUS_ADJOINT in order to see the fields available for the adjoint solvers.
Get involved:
Old   February 11, 2020, 17:56
cfdjetman
Thanks, I was able to find the required options.
However, I ran into few problems.
1. When I use the parallel_computation.py script to run the cfd simulation over an airfoil, the surface_flow.csv only contains data from the leading edge to approx. 0.3*chord length. The rest of the data is missing.
2. When I use the discrete_adjoint.py script to run both the cfd and the adjoint simulations, the surface_adjoint.csv and surface_sens.csv only contains data from around 0.7*chord length to the trailing edge. The surface_flow.csv in this case has the exact same data as the surface_adjoint.csv file.
These are the settings I used to print out this data
% Screen output
SCREEN_OUTPUT=(INNER_ITER, RMS_DENSITY, RMS_NU_TILDE, LIFT, DRAG, SENS_GEO, SENS_AOA, RMS_ADJ_DENSITY, RMS_ADJ_NU_TILDE)
% History output groups (use 'SU2_CFD -d <config_file>' to view list of available fields)
HISTORY_OUTPUT= (ITER, RMS_RES, AERO_COEFF, AOA, WALL_TIME, MAX_RES, BGS_RES, SENSITIVITY)
% Volume output fields/groups (use 'SU2_CFD -d <config_file>' to view list of available fields)
VOLUME_OUTPUT= (COORDINATES, SOLUTION, PRIMITIVE, SENSITIVITY)
rgbatista likes this.
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 13:08
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
RNG diverged during the analysis the flow over a multi element airfoil, why? s.m OpenFOAM Running, Solving & CFD 0 August 5, 2013 09:39
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
lift and drag on ship superstructures vaina74 OpenFOAM Running, Solving & CFD 3 June 8, 2010 13:30
