Home > Forums > Software User Forums > SU2
Inviscid Supersonic Wedge Tutorial similar mesh but different shock resolution?
Old   February 24, 2020, 21:30
Default Inviscid Supersonic Wedge Tutorial similar mesh but different shock resolution?
Rahul
r.s. is on a distinguished road
Hi Everyone,
I was testing "Inviscid Supersonic Wedge" tutorial from SU2 (v7.0.0) and observed some weird thing.
Case 1: Download mesh (.cgns) and configuration file from "su2code.github.io/Inviscid_Wedge/" and run the case. Solution looks smooth near shock with .cgns mesh and even with .su2 mesh generated using SU2_DEF.
Case 2: Download configuration file only form github-SU2 and generate .su2 mesh using Gmsh with same number of nodes and elements as in tutorial mesh. But now the solution with this mesh file does not look smooth near shock. (see attached Mach contour).
I checked both mesh, Gmsh generated and tutorial mesh in Paraview and both are exactly same and I am using same configuration file but still the results are different.
Any suggestions on this?Why its happening? (.cfg and both mesh file attached).
r.s. is offline   Reply With Quote
Old   May 13, 2020, 16:14
ines_cardoso is on a distinguished road
I am interested in generating the same mesh, but I can't figure out how to refine the mesh near the shock using gmsh. Do you think you can share the .geo file, or the command lines you used in the script file to refine the mesh there?
ines_cardoso is offline   Reply With Quote
Old   May 13, 2020, 19:02
pcg
Pedro Gomes
pcg is on a distinguished road
See my reply here: https://github.com/su2code/SU2/issue...ment-591947858
pcg is offline   Reply With Quote
gmsh, inviscid, su2, supersonic, wedge
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Mesh similar to tutorial 20 Marie S CFX 1 August 27, 2008 04:25
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
