I had the same issue from my LES results. So I generated my small size vtk from restart.dat file in MATLAB because my system freeze whenever I tried opening .vtu files from LES data dumped from SU2 code. So may be its just issue with code.
opening vtu files from SU2 7.0.6 in Paraview 5.8.1
I guess it won't be too long before SU2 7.0.7 appears !!
Thanks |
Paraview and large vtu error
I am trying to open a large VTU file using Paraview. There are around 400000 unstructured data points in it. But in Paraview when I want to open it I get the following error: "cannot read cell offsets from cells in piece 0 because the offset" I tried Paraview versions 5.5, 5.6, 5.7, 5.8 & 5.9 on two different versions of Ubuntu and on Windows, but the error is the same. I have also tried installing SU2, but it did not work for me. Also, I tried pasting the following into my configuration file: OUTPUT_FILES= PARAVIEW_ASCII, however, it did not solve my problem either. I appreciate any help. Thanks E30 |
opening vtu file from SU2 7.0.5 in Paraview
May be try the the latest versions 7.1... onwards of SU2
Some of the earlier versions had issues in the vtu files |
