Temp file location for SU2 in windows
I am new to SU2 solver as well as new to Open Source Tool world. I have two doubts. 1. I am running Tutorial file ONERA M6 Turbulent Flow. The mesh is CGNS format and Mesh size is pretty big (20 Millions). I am running on 16GB machine in series. Unfortunately, my C drive is getting full and there is no more space. Could you all help me to understand, if there is any temp file created during SU2 run. If yes.. what would be location. Advance thanks for answering. |
SU2 writes a history file (named history.csv by default) and the other outputs depend on the config setting. Usually there would be a restart file (named restart_flow.dat by default) and some solution files (flow.* or surface_flow.*). All the files are written in whatever directory you are running the executable.
