3D Residuals visualisation in ParaView?
Is it possible to view cell/volume residuals within ParaView for SU2 simulations? I want to see which areas of my geometry have the highest residual values so I can refine the grid in that region.
I have ran SU2_SOL for my most recent simulation, opened the flow.vtk file in ParaView, and only the following options are available: Density Energy Heat_flux Lam_Viscosity Mach Momentum Pressure Pressure_Coeff Skin_f_Coeff Temp Thanks |
You need to ask for the residual output.
VOLUME_OUTPUT= PRIMITIVE, RESIDUAL |
I've tried VOLUME_OUTPUT = RESIDUAL as well and it returns the same Solved: WRT_RESIDUAL= YES |
Good to know the issue was solved. The VOLUME_OUTPUT option is available from v7 onwards. Cheers. |
