Home > Forums > Software User Forums > SU2
Default Turbulence Intensity value in SU2 6.2.0 Falcon
Old   September 30, 2020, 13:18
Default Default Turbulence Intensity value in SU2 6.2.0 Falcon
Manoj Kumar
mjkr2102 is on a distinguished road
I have used SU2 6.2.0 Falcon to run turbulent simulations using SA model. The configuration file that I had used does not contain an input "FREESTREAM_TURBULENCEINTENSITY". If the turbulence intensity is not specified in the configuration file, the code may use a default value for the same. If so, what is the default value of turbulence intensity?
mjkr2102 is offline   Reply With Quote
Old   September 30, 2020, 14:37
Amit
aero_amit is on a distinguished road
It's default value is set to 0.05. You can check config_structure.cpp in Common/src folder.
aero_amit is offline   Reply With Quote
Old   September 30, 2020, 16:09
Manoj Kumar
Thank you for the information. 0.05 would correspond to 5%? Please correct me if I am wrong.
Old   September 30, 2020, 21:02
Amit
Yes.
To add further, for external aero usually we take 0.001 or 0.002 type (0.1% or 0.2%) and for internal flow (wt model) depending upon inputs available 0.01 to 0.05 (1% to 5%).
falcon, turbulence intensity
Turbulence intensity plummets Piedrapablo FLUENT 1 February 5, 2017 23:28
Turbulence intensity from experimental data ArathoN Main CFD Forum 2 November 22, 2014 06:07
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 14:32
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Turbulence Intensity Vs CFD Simulation Apple L S Chan Main CFD Forum 3 December 15, 1998 17:28
