Home > Forums > Software User Forums > SU2
Shift in PSD peaks with increased inner iterations
Old   June 15, 2021, 10:12
Question Shift in PSD peaks with increased inner iterations
Ravi
raviramesh10 is on a distinguished road
Hello all,
I am currently running a DDES, 2nd order unsteady simulation for an airfoil in deep stall (angle of attack = 60^{\circ}). The time discretization was performed by using a dual time-stepping scheme. I was trying to converge the results obtained from SU2, and compare the variation of C_{l} experimental data by increasing the number of inner iterations.
I seem to be finding it difficult to obtain a physical reason behind the shift in the peak frequency for which I have obtained. In consultation with another colleague, I got to know that the reason could be because of the absence of ensemble averaging. I would be grateful to hear from someone regarding their opinion on this matter.
The experimental data and the computational results were obtained from Swalwell et. al. and the DESider project respectively, whose sources are presented below:
Hoping to hear soon.
References:
Katrina E Swalwell, John Sheridan, WH Melbourne, et al. The effect of turbulence intensity on stall of the naca 0021 aerofoil. In 14th Australasian fluid mechanics conference, pages 10–14, 2001.
Werner Haase, Marianna Braza, and Alistair Revell.DESider–A European Effort on HybridRANS-LES Modelling: Results of the European-Union Funded Project, 2004-2007, volume103. Springer Science & Business Media, 2009.
raviramesh10 is offline   Reply With Quote
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 13:47
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
