December 6, 2018, 12:38 |
SU2 Parallel Build Issue
Rep Power: 7 |
I've spent some time trying to compile the parallel build for SU2 without much success (not that familiar with this type of stuff) after having installed a working serial build. I have searched and troubleshot but am still ending up having my lines repeated as the processors each tackle the problem individually rather than combine their efforts. I've seen in other posts that this means that I have not compiled it correctly but I do not know where to go to fix it.
Here is an example of the code being produced several times over: Code:
---------------------- Local Time Stepping Summary ---------------------- MG level: 0 -> Min. DT: 0.0014005. Max. DT: 6.28794. CFL: 25. MG level: 1 -> Min. DT: 0.00204115. Max. DT: 9.19148. CFL: 21.1166. MG level: 2 -> Min. DT: 0.00189142. Max. DT: 14.7692. CFL: 19.4394. ------------------------------------------------------------------------- ----------------------- Residual Evolution Summary ---------------------- log10[Maximum residual]: -4.05266. Maximum residual point 18259, located at (0.146565, 0.155084, -0.025158). ------------------------------------------------------------------------- Iter Time(s) Res[Rho] Res[RhoE] CL(Total) CD(Total) 0 19.109375 -5.204928 -4.597762 0.166106 0.052986 1 17.406250 -4.668226 -4.054766 0.235420 0.045799 1 17.468750 -4.668226 -4.054766 0.235420 0.045799 1 17.546875 -4.668226 -4.054766 0.235420 0.045799 1 17.765625 -4.668226 -4.054766 0.235420 0.045799 2 16.973958 -4.750446 -4.158519 0.255504 0.029367 2 17.062500 -4.750446 -4.158519 0.255504 0.029367 2 17.145833 -4.750446 -4.158519 0.255504 0.029367 2 17.317708 -4.750446 -4.158519 0.255504 0.029367 3 16.761719 -4.803657 -4.218884 0.272734 0.022452 3 16.882812 -4.803657 -4.218884 0.272734 0.022452 3 16.949219 -4.803657 -4.218884 0.272734 0.022452 3 17.121094 -4.803657 -4.218884 0.272734 0.022452 Code:
jclegg@DESKTOP-CD3IBI9:/mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0$ ./configure --prefix=/mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0 CXXFLAGS="-O3" --enable-mpi --with-cc=/usr/bin/mpicc --with-cxx=/usr/bin/mpicxx checking build system type... x86_64-unknown-linux-gnu checking host system type... x86_64-unknown-linux-gnu checking target system type... x86_64-unknown-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking for style of include used by make... GNU checking whether the C++ compiler works... yes checking for C++ compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether /usr/bin/mpicxx accepts -g... yes checking dependency style of /usr/bin/mpicxx... gcc3 checking whether we are using the GNU C compiler... yes checking whether /usr/bin/mpicc accepts -g... yes checking for /usr/bin/mpicc option to accept ISO C89... none needed checking dependency style of /usr/bin/mpicc... gcc3 checking whether /usr/bin/mpicc and cc understand -c and -o together... yes checking for ranlib... ranlib checking whether we are using the GNU C++ compiler... (cached) yes checking whether /usr/bin/mpicxx accepts -g... (cached) yes checking dependency style of /usr/bin/mpicxx... (cached) gcc3 checking for python... /usr/bin/python checking for python version... 2.7 checking for python platform... linux2 checking for python script directory... ${prefix}/lib/python2.7/site-packages checking for python extension module directory... ${exec_prefix}/lib/python2.7/site-packages checking for python2.7-config... /usr/bin/python2.7-config checking python include flags... -I/usr/include/python2.7 -I/usr/include/x86_64-linux-gnu/python2.7 checking how to run the C preprocessor... /usr/bin/mpicc -E checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking size of short int... 2 checking size of int... 4 checking size of unsigned int... 4 checking size of long int... 8 checking size of float... 4 checking size of double... 8 checking size of void *... 8 checking X11/Intrinsic.h usability... no checking X11/Intrinsic.h presence... no checking for X11/Intrinsic.h... no <<< Configuring library with Metis support >>> <<< Configuring library with Parmetis support >>> <<< Configuring library with CGNS support >>> checking that generated files are newer than configure... done configure: creating ./config.status config.status: creating externals/tecio/Makefile config.status: creating externals/metis/Makefile config.status: creating externals/parmetis/Makefile config.status: creating externals/cgns/Makefile config.status: creating Makefile config.status: creating externals/Makefile config.status: creating Common/lib/Makefile config.status: creating SU2_CFD/obj/Makefile config.status: creating SU2_DOT/obj/Makefile config.status: creating SU2_MSH/obj/Makefile config.status: creating SU2_DEF/obj/Makefile config.status: creating SU2_SOL/obj/Makefile config.status: creating SU2_GEO/obj/Makefile config.status: creating SU2_PY/Makefile config.status: creating SU2_PY/pySU2/Makefile config.status: executing depfiles commands ------------------------------------------------------------------------- | ___ _ _ ___ | | / __| | | |_ ) Release 6.1.0 'Falcon' | | \__ \ |_| |/ / | | |___/\___//___| Suite | | | ------------------------------------------------------------------------- | The current SU2 release has been coordinated by the | | SU2 International Developers Society <www.su2devsociety.org> | | with selected contributions from the open-source community. | ------------------------------------------------------------------------- | The main research teams contributing to the current release are: | | - Prof. Juan J. Alonso's group at Stanford University. | | - Prof. Piero Colonna's group at Delft University of Technology. | | - Prof. Nicolas R. Gauger's group at Kaiserslautern U. of Technology. | | - Prof. Alberto Guardone's group at Polytechnic University of Milan. | | - Prof. Rafael Palacios' group at Imperial College London. | | - Prof. Vincent Terrapon's group at the University of Liege. | | - Prof. Edwin van der Weide's group at the University of Twente. | | - Lab. of New Concepts in Aeronautics at Tech. Inst. of Aeronautics. | ------------------------------------------------------------------------- | Copyright 2012-2018, Francisco D. Palacios, Thomas D. Economon, | | Tim Albring, and the SU2 contributors. | | | | SU2 is free software; you can redistribute it and/or | | modify it under the terms of the GNU Lesser General Public | | License as published by the Free Software Foundation; either | | version 2.1 of the License, or (at your option) any later version. | | | | SU2 is distributed in the hope that it will be useful, | | but WITHOUT ANY WARRANTY; without even the implied warranty of | | MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU | | Lesser General Public License for more details. | | | | You should have received a copy of the GNU Lesser General Public | | License along with SU2. If not, see <http://www.gnu.org/licenses/>. | ------------------------------------------------------------------------- Build Configuration Summary: Source code location: /mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0 Install location: /mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0 Version: 6.1.0 C++ Compiler: /usr/bin/mpicxx C Compiler: /usr/bin/mpicc Preprocessor flags: -DHAVE_MPI Compiler flags: -O3 Linker flags: MPI support: yes Metis support: yes Parmetis support: yes TecIO support: no CGNS support: yes HDF5 support: no SZIP support: no ZLIB support: no Mutation++ support: no Jsoncpp support: no LAPACK support: no Datatype support: double yes complex no codi_reverse no codi_forward no External includes: -DHAVE_CGNS -I$(top_srcdir)/externals/cgns -I$(top_srcdir)/externals/cgns/adf -DHAVE_PARMETIS -I$(top_srcdir)/externals/parmetis/include -DHAVE_METIS -I$(top_srcdir)/externals/metis/include External libs: $(top_builddir)/externals/cgns/libcgns.a $(top_builddir)/externals/parmetis/libparmetis.a $(top_builddir)/externals/metis/libmetis.a Build SU2_CFD: yes Build SU2_DOT: yes Build SU2_MSH: yes Build SU2_DEF: yes Build SU2_SOL: yes Build SU2_GEO: yes Build Py Wrapper: no Please be sure to add the $SU2_HOME and $SU2_RUN environment variables, and update your $PATH (and $PYTHONPATH if applicable) with $SU2_RUN. Based on the input to this configuration, add these lines to your .bashrc file: export SU2_RUN="/mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0/bin" export SU2_HOME="/mnt/c/Users/Jon/Documents/SU2_Falcon/SU2-6.1.0" export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN Last edited by jclegg; December 6, 2018 at 15:41. |
December 10, 2018, 05:16 |
Pedro Gomes
Rep Power: 13 |
If you installed a serial version there is a chance that you are now pointing to that version when calling SU2_CFD.
Try running mpirun with the absolute path to the executable that resulted from your parallel compilation. |
October 12, 2020, 12:30 |
ugurtan
Rep Power: 5 |
I have the same problem for a couple of days and it is really frustrating to overcome with it. Any help would be beneficial.
October 12, 2020, 13:06 |
Pedro Gomes
Rep Power: 13 |
Follow these instructions: https://su2code.github.io/docs_v7/Bu...2-Linux-MacOS/
(if you are on Windows I will not be able to help) And post the entire output of the process, I will have a look but what often happens is: You built a serial version because mpi was not detected. You build a parallel version with one mpi distribution, and now tried to run it with a different mpi... The same applies if you are using the pre-compiled binaries, you must run them with the same version of MPI listed here: https://su2code.github.io/docs_v7/SU2-Linux-MacOS/ |
October 20, 2020, 04:28 |
Hyun Ko
Rep Power: 16 |
Need to check you mpi.
If your system has mpich and openmpi, please check which mpirun is used to run SU2. If you compile SU2 by mpich and run it by openmpi, then multiple out can be shown. |
build, parallel, su2 |
Display Modes | |
error make SU2 4.0.1 | Heathckliff | SU2 Installation | 2 | November 9, 2015 05:48 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 11:58 |
Building from Source on Windows using Cygwin64 | ericthefatguy | SU2 | 2 | May 12, 2015 18:23 |
Scaling for parallel run for SU2 | nileshjrane | SU2 | 1 | January 1, 2015 20:06 |
SU2 Parallel - cannot access or exectute | dbaldzhiev | SU2 | 3 | November 24, 2014 17:02 |
