November 30, 2020, 07:50 |
SU2 V7 Residual Evolution Summary
Ettore Saetta
Rep Power: 6 |
Hello to everyone,
I have a question about the scrren output in the latest version of SU2. Is it possible to have a Residual Evolution Summary as the same (or a similar one) present in the SU2 V6? I have seen that one of the options of the SCREEN_OUTPUT is the MAX_DENSITY, but I also need the ID cell or the cell coordinates corresponding to this maximum residual value. Is it possible to print this information in the screen output? Thanks in advance for your reply. Best, Ettore Saetta |
December 2, 2020, 09:48 |
Amit
Rep Power: 12 |
You can run command -
SU2_CFD -d filename.cfg This will tell you possible/available screen/history output fields and volume output fields for your .cfg file settings. You can print fields, you use to get in V6. For example force/ moment coefficients, CFL, wall time, no of Nonphysical points etc. I am not sure about the locations or cell ID for max residual, it is not obvious from above options. |
December 2, 2020, 10:49 |
Pedro Gomes
Hello Ettore,
It seems in the new output there is no way to display that information. It is still computed in the solvers but there is no function to print it. Regards, Pedro |
December 4, 2020, 06:26 |
#4 | |
Ettore Saetta
Rep Power: 6 |
I have already tried with this command, but I didn't find any option to print the cell ID for max residual. |
December 4, 2020, 06:29 |
#5 | |
Ettore Saetta
Rep Power: 6 |
thanks for your reply. Maybe a possibility is to implement a function that print this information. Regards, Ettore |
output, residual, screen, su2 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
chtMultiRegionSimpleFoam turbulent case | Aditya Patil | OpenFOAM Running, Solving & CFD | 6 | April 24, 2017 22:13 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
