Inlet profile for SST with nondimensional treatment |
October 31, 2021, 06:27 |
Zhen ZHANG
Rep Power: 7 |
Hi all,
I am trying the SST turbulence model with an inlet profile and the nondimensional treatment (FREESTREAM_VEL_EQ_ONE). I am wondering whether the TKE and Omega in the inlet profile should be nondimensionalized when making the profile. With the dimensional values, the solver does not converge well. The inlet profile for the SA model seems not to be affected by the nondimensional treatment, is that right? Thanks Zhen |
November 1, 2021, 11:05 |
na
Rep Power: 7 |
from a short look into the code I would say they have to be nondimensional. Which your findings support. A way to check could be via the automatic example_file writing when no inlet is present. If those values are non-dim then you can be pretty sure that you have to feed non-dim values as well. The Treatment for SA and SST looks very similar as well ... and there is non-Dimensionalization for nu-tilde so that should apply as well. For the non-dim Factor please see the the Reference value section which is written in the screen output at simulation beginning Good point btw, I'll take a look how and where we could document that . Best, Tobi |
November 1, 2021, 22:06 |
Zhen ZHANG
Rep Power: 7 |
Hi Tobi,
Thank you for the reply. I checked the CSolver::LoadInletProfile and find the following: Code:
//for SA columnValue << config->GetNuFactor_FreeStream()*config->GetViscosity_FreeStreamND()/config->GetDensity_FreeStreamND() <<"\t"; //for SST columnValue << config->GetTke_FreeStream() << "\t" << config->GetOmega_FreeStream() <<"\t"; Zhen |
November 3, 2021, 11:23 |
na
Rep Power: 7 |
Nice find!
Also dont hesitate to change bits of the code, compile and see how the results turn out. In case that helps you could even open a new PR on github (but I recall you mentioned some difficulties with working on github). I am currently also debugging some things for multiple inlet markers with specified inlet profiles (inc flow + sst + species transport) so I hope to fix that any problems soon. In any case I'll let you know here |
November 4, 2021, 01:35 |
Zhen ZHANG
Rep Power: 7 |
Thanks and good luck!
November 10, 2021, 08:19 |
na
Rep Power: 7 |
Hi Zhen,
the issue will be fixed in develop with https://github.com/su2code/SU2/pull/1427 (Edit: it is now merged into develop, so I hope this fixes it for you) So what made me state that the values from the inlet file have to be non-dimensional (in case of a non-dim simulation of course) is that after reading the inlet values they are never non-dimensionalized... so they would have worked in case they were non-dimensionalized. The problem is now, that for SST, TKE and Omega are written dimensional for the example file but the solver expects non-dimensional values. I now changed it that all values in the inlet file are dimensional (and the example writes dimensional values only) and the values are non-dimensionalized directly when they are used in the inlet. That is consistent with the mean flow quantities. If you can test it and tell me whether that worked for you, that would be awesome. Note that I only tested incompressible flow, but it should have fixed compressible as well Last edited by TKatt; November 10, 2021 at 10:37. |
November 16, 2021, 02:12 |
Zhen ZHANG
Rep Power: 7 |
Hi Tobi,
Sorry for late reply. I pulled the develop branch to test it, but the compile failed. Code:
../SU2_CFD/src/numerics/turbulent/turb_sources.cpp:764:62: error: invalid initializer for array member ‘su2double CSourcePieceWise_TurbSST<CEulerVariable::CIndices<short unsigned int> >::Jacobian_Buffer [4]’ idx(val_nDim, config->GetnSpecies()) { Zhen |
November 16, 2021, 03:52 |
na
Rep Power: 7 |
Do you use gnu/4.8.5 by any chance? I suspect the
Jacobian_Buffer[4] = {0.0}; So a quick test would be to just make it Code:
Jacobian_Buffer[4]; |
November 17, 2021, 15:02 |
#9 |
na
Rep Power: 7 |
Little update:
If you now pull the very latest my suggested change is already incorporated. See https://github.com/su2code/SU2/pull/1445 So I hope this fixes it for you. It would be great to hear if the compiling and inlet files now work for you |
November 18, 2021, 08:54 |
#10 |
Zhen ZHANG
Rep Power: 7 |
Hi Tobi,
Thank you for your help. Yes, I am using 4.8.5. I tried several times these days but cannot pull the code from Github. So I just modified the code to Code:
Jacobian_Buffer[4]; Now both the compiling and inlet profile work well for me. The dimensional value in the example_inlet.dat is very convenient. Thanks again Zhen |
November 18, 2021, 12:25 |
#11 |
na
Rep Power: 7 |
Awesome, That is good to hear that it now works for you Thanks for your debugging work !
Parabolic Velocity inlet profile error | guerillagecko | SU2 | 1 | April 16, 2021 17:09 |
Spatio-temporal Inlet Velocity Profile from measurements for LES | MariosReizo | Main CFD Forum | 9 | March 5, 2021 05:23 |
Defining 2D Temperature Profile for two inlet patches | afzaal | Fidelity CFD | 0 | April 12, 2017 00:48 |
How to obtain a fully-developed profile in a inlet? (ANSYS WORKBENCH) | Il_cardozo | ANSYS | 0 | November 21, 2016 08:40 |
Inlet Boundary profile for compressible flow | uday sarkar | FLUENT | 1 | November 20, 2015 09:24 |
