SU2 process returned error '15' during optimization |
January 23, 2021, 10:18 |
Bikalpa Bomjan Gurung
Rep Power: 13 |
Hello everyone,
I am using the SU2_7.0.6 version for 3d optimization with High-Performance Computer having 40 processors on each node. My slurm file is as follows. #!/bin/bash #SBATCH --job-name=Delta_5 #SBATCH --nodes=3 #SBATCH --ntasks=120 #SBATCH --time=24:00:00 #SBATCH -o slurmjob-%j.out #SBATCH -e slurmjob-%j.err module load compiler/openmpi/3.1.0/gnu module load python/3.6 export SU2_RUN=/home/apps/su2_7.0.6_AD_support/SU2_7.0.6/bin export SU2_HOME=/home/apps/su2_7.0.6_AD_support/SU2_7.0.6/SU2-7.0.6 export PATH=$PATH:$SU2_RUN export PYTHONPATH=$PYTHONPATH:$SU2_RUN export SU2_MPI_COMMAND="mpirun -np %i %s" shape_optimization.py -n 120 -o SLSQP -f turb_Corr_Del_5_optimisation.cfg While using more than 1 node for optimization it runs for 2-3 iterations and the optimization stops with the error message “SU2 process returned error '15' Abort(811688463) on node 17 (rank 17 in comm 0): Fatal error in PMPI_Finalize: Other MPI error, error stack: PMPI_Finalize(367)...............: MPI_Finalize failed PMPI_Finalize(278)...............: MPID_Finalize(1033)..............: MPIDI_OFI_mpi_finalize_hook(1579): OFI domain close failed (ofi_init.c:1579:MPIDI_OFI_mpi_finalize_hookevic e or resource busy) ” The process runs for 2-3 more iteration when restarting the project and the same error repeats. Please suggest what might be causing this error and how I can overcome this issue. Thank you Regards Bikalpa Bomjan Gurung |
Display Modes | |
SU2 Optimization multiple FFD boxes error | StanislavKarpuk | SU2 Shape Design | 0 | November 20, 2019 16:51 |
Introducing SU2 International Developers Society (IDS) | fpalacios | SU2 News & Announcements | 1 | June 17, 2019 23:38 |
Pointwise-SU2 joint webinar (April 29th) and SU2 v3.1.0 new release | fpalacios | SU2 News & Announcements | 1 | April 30, 2014 03:40 |
error 262144 and unexpected disconnect when run on 2 nodes | Emily1412 | SU2 Installation | 1 | April 10, 2014 18:08 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 16:15 |
