February 18, 2021, 14:52 |
What could be causing this divergence issue?
Bradley Craig
Rep Power: 5 |
Hello all,
I've recently started getting this error from a simulation and was wondering if anyone knows the cause? Thanks in advance |
February 18, 2021, 14:54 |
Here is my cfg file for reference
Bradley Craig
Rep Power: 5 |
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% % Physical governing equations (EULER, NAVIER_STOKES, NS_PLASMA) % SOLVER= RANS % % Specify turbulent model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SA % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % ------------------------- UNSTEADY SIMULATION -------------------------------% % TIME_DOMAIN= YES % % Numerical Method for Unsteady simulation(NO, TIME_STEPPING, DUAL_TIME_STEPPING-1ST_ORDER, DUAL_TIME_STEPPING-2ND_ORDER, TIME_SPECTRAL) TIME_MARCHING= DUAL_TIME_STEPPING-2ND_ORDER % % Time Step for dual time stepping simulations (s) TIME_STEP= 1e-3 % % Maximum Number of physical time steps. TIME_ITER= 9999999 % % Number of internal iterations (dual time method) INNER_ITER= 9000 % % -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------% % % Mach number (non-dimensional, based on the free-stream values) MACH_NUMBER= 0.2 % % Angle of attack (degrees, only for compressible flows) AOA= 0.0 % % De-Dimensionalization REF_DIMENSIONALIZATION = DIMENSIONAL % % Free-stream temperature (288.15 K by default) FREESTREAM_TEMPERATURE= 288.15 % % Reynolds number (non-dimensional, based on the free-stream values) REYNOLDS_NUMBER= 1.2e+6 % % Reynolds length (1 m by default) REYNOLDS_LENGTH= 1.0 % % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= SUTHERLAND % % Sutherland Viscosity Ref (1.716E-5 default value for AIR SI) MU_REF= 1.716e-5 % % Sutherland Temperature Ref (273.15 K default value for AIR SI) MU_T_REF= 273.15 % % Sutherland constant (110.4 default value for AIR SI) SUTHERLAND_CONSTANT= 110.4 % % ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------% % % Different gas model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS) FLUID_MODEL= STANDARD_AIR % % Ratio of specific heats (1.4 default and the value is hardcoded % for the model STANDARD_AIR) GAMMA_VALUE= 1.4 % % Specific gas constant (287.058 J/kg*K default and this value is hardcoded % for the model STANDARD_AIR) GAS_CONSTANT= 287.058 % % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.00 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0 % % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( cylinder, 0.0 ) % % Farfield boundary marker(s) (NONE = no marker) MARKER_FAR= ( farfield ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( cylinder ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( cylinder ) % % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 7 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 0.5, 1, 1, 25 ) % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Linear solver for the implicit formulation (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % LINEAR_SOLVER_PREC= ILU % LINEAR_SOLVER_ILU_FILL_IN= 0 % LINEAR_SOLVER_SMOOTHER_RELAXATION= 1.0 % % Min error of the linear solver for the implicit formulation LINEAR_SOLVER_ERROR= 1E-3 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 10 % % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= ROE % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) MUSCL_FLOW= NO % SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % VENKAT_LIMITER_COEFF= 0.05 % % 1st, 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Spatial numerical order integration (1ST_ORDER, 2ND_ORDER, 2ND_ORDER_LIMITER) MUSCL_TURB= NO % % Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, % BARTH_JESPERSEN, VAN_ALBADA_EDGE) % SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) CONV_CRITERIA = RESIDUAL % Field to apply Cauchy Criterion to CONV_FIELD= RMS_DENSITY % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -6 % %% Time convergence monitoring WINDOW_CAUCHY_CRIT = YES % % List of time convergence fields CONV_WINDOW_FIELD = (TAVG_DRAG, TAVG_LIFT) % % Time Convergence Monitoring starts at Iteration WINDOW_START_ITER + CONV_WINDOW_STARTITER CONV_WINDOW_STARTITER = 0 % % Epsilon to control the series convergence CONV_WINDOW_CAUCHY_EPS = 1E-3 % % Number of elements to apply the criteria CONV_WINDOW_CAUCHY_ELEMS = 100 % % Starting iteration for windowed-time-averaging WINDOW_START_ITER = 100 % % Window used for reverse sweep. Options (SQUARE, HANN, HANN_SQUARE, BUMP) WINDOW_FUNCTION = HANN_SQUARE % % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % HISTORY_WRT_FREQ_INNER=0 SCREEN_WRT_FREQ_INNER =1 % OUTPUT_FILES= CSV, PARAVIEW, SURFACE_PARAVIEW % % Mesh input file MESH_FILENAME= cylinder.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart adjoint input file SOLUTION_ADJ_FILENAME= restart_adj.dat % % Output file convergence history (w/o extension) CONV_FILENAME= 0_history % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= CSV % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % SCREEN_OUTPUT=(TIME_ITER, INNER_ITER, DRAG, LIFT, RMS_DENSITY, REL_RMS_DENSITY, CAUCHY_TAVG_DRAG, CAUCHY_TAVG_LIFT) HISTORY_OUTPUT=(ITER,REL_RMS_RES,RMS_RES, AERO_COEFF,TAVG_AERO_COEFF, CAUCHY) % |
February 19, 2021, 08:17 |
bigfoot
Rep Power: 17 |
so you did not get this error previously? What did you change? When you get this at the start of your run, something could be wrong with the initial solution of the problem, or You start with too aggressive settings. You could try lowering your CFL or your timestep
divergence detected, error |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
FSI. Fluent divergence issue due to Dynamic Mesh | Svensen | ANSYS | 2 | January 28, 2016 01:41 |
Divergence issue with SST Turb Model | jehanz | SU2 | 3 | May 19, 2015 18:01 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
