February 21, 2021, 10:55 |
SU2 Min and Max coodinates
Rep Power: 5 |
I am trying to solve for a flow in a converging nozzle, but I keep getting an error stating: FGMRES orthogonalization failed, linear solver diverged.
I have also noticed after analysing the output from SU2 that it has detected the following: Wetted area = 0 m. Area projection in the x-plane = 0 m, y-plane = 0 m. Max. coordinate in the x-direction = -1e+010 m, y-direction = -1e+010 m. Min. coordinate in the x-direction = 1e+010 m, y-direction = 1e+010 m. The detected minimum and maximum coordinates are not consistent with the actual values. Also the area values are 0. I have tried using the same mesh (different format) on Fluent and it runs fine. I am only getting the diverging problem on SU2. Any ideas? |
February 21, 2021, 17:11 |
Pedro Gomes
Rep Power: 13 |
Assuming you are exporting the grid in CGNS format, change the CGNS options (ADF / HDF) I am not sure which one we support, but there are not that many options.
Display Modes | |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Converging Diverging Nozzle with dbnsTurbFoam | Saleh Abuhanieh | OpenFOAM Running, Solving & CFD | 4 | December 13, 2019 10:26 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
