Home > Forums > Software User Forums > SU2
Optimization of Nozzle in SU2
Old   July 15, 2021, 02:04
Default Optimization of Nozzle in SU2
Abhishek Karn
abk1234 is on a distinguished road
am trying to optimize nozzle shape for maximum mach number. I am confused whether I can SURFACE_MACH objective function for that purpose. When I optimize for SURFACE_MACH , I get 0 gradient .
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
% Physical governing equations (EULER, NAVIER_STOKES,
% FEM_EULER, FEM_NAVIER_STOKES, FEM_RANS, FEM_LES,
% WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY,
% POISSON_EQUATION)
SOLVER= RANS
% Specify turbulence model (NONE, SA, SA_NEG, SST, SA_E, SA_COMP, SA_E_COMP)
KIND_TURB_MODEL= SST
% Mathematical problem (DIRECT, CONTINUOUS_ADJOINT, DISCRETE_ADJOINT)
MATH_PROBLEM= CONTINUOUS_ADJOINT
% Restart solution (NO, YES)
RESTART_SOL= YES
% System of measurements (SI, US)
% International system of units (SI): ( meters, kilograms, Kelvins,
% Newtons = kg m/s^2, Pascals = N/m^2,
% Density = kg/m^3, Speed = m/s,
% Equiv. Area = m^2 )
% United States customary units (US): ( inches, slug, Rankines, lbf = slug ft/s^2,
% psf = lbf/ft^2, Density = slug/ft^3,
% Speed = ft/s, Equiv. Area = ft^2 )
SYSTEM_MEASUREMENTS= SI
% -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------%
% Mach number (non-dimensional, based on the free-stream values)
MACH_NUMBER= 0.086
% Angle of attack (degrees, only for compressible flows)
AOA= 0.0
% Side-slip angle (degrees, only for compressible flows)
SIDESLIP_ANGLE= 0.0
% Init option to choose between Reynolds (default) or thermodynamics quantities
% for initializing the solution (REYNOLDS, TD_CONDITIONS)
INIT_OPTION= TD_CONDITIONS
% Free-stream option to choose between density and temperature (default) for
% initializing the solution (TEMPERATURE_FS, DENSITY_FS)
FREESTREAM_OPTION= TEMPERATURE_FS
% Free-stream pressure (101325.0 N/m^2, 2116.216 psf by default)
FREESTREAM_PRESSURE= 101325.0
% Free-stream temperature (288.15 K, 518.67 R by default)
FREESTREAM_TEMPERATURE= 288.15
% Compressible flow non-dimensionalization (DIMENSIONAL, FREESTREAM_PRESS_EQ_ONE,
% FREESTREAM_VEL_EQ_MACH, FREESTREAM_VEL_EQ_ONE)
REF_DIMENSIONALIZATION= DIMENSIONAL
% ---- IDEAL GAS, POLYTROPIC, VAN DER WAALS AND PENG ROBINSON CONSTANTS -------%
% Fluid model (STANDARD_AIR, IDEAL_GAS, VW_GAS, PR_GAS,
% CONSTANT_DENSITY, INC_IDEAL_GAS, INC_IDEAL_GAS_POLY)
FLUID_MODEL= STANDARD_AIR
% Ratio of specific heats (1.4 default and the value is hardcoded
% for the model STANDARD_AIR, compressible only)
GAMMA_VALUE= 1.4
% Specific gas constant (287.058 J/kg*K default and this value is hardcoded
GAS_CONSTANT= 287.058
% Critical Temperature (131.00 K by default)
CRITICAL_TEMPERATURE= 131.00
% Critical Pressure (3588550.0 N/m^2 by default)
CRITICAL_PRESSURE= 3588550
% Acentric factor (0.035 (air))
ACENTRIC_FACTOR= 0.035
% --------------------------- VISCOSITY MODEL ---------------------------------%
% Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY, POLYNOMIAL_VISCOSITY).
VISCOSITY_MODEL= CONSTANT_VISCOSITY
% Molecular Viscosity that would be constant (1.716E-5 by default)
MU_CONSTANT= 1.716E-05
% --------------------------- THERMAL CONDUCTIVITY MODEL ----------------------%
% Laminar Conductivity model (CONSTANT_CONDUCTIVITY, CONSTANT_PRANDTL,
% POLYNOMIAL_CONDUCTIVITY).
CONDUCTIVITY_MODEL= CONSTANT_PRANDTL
% Molecular Thermal Conductivity that would be constant (0.0257 by default)
KT_CONSTANT= 0.0257
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
% Navier-Stokes (no-slip), constant heat flux wall marker(s) (NONE = no marker)
% Format: ( marker name, constant heat flux (J/m^2), ... )
MARKER_HEATFLUX= ( WALL, 0.0 )
% Symmetry boundary marker(s) (NONE = no marker)
MARKER_SYM= ( SYMMETRY)
% Riemann boundary marker(s) (NONE = no marker)
% Format: (marker, data kind flag, list of data)
MARKER_RIEMANN= ( INFLOW, TOTAL_CONDITIONS_PT, 101831.3, 286.75, 1.0, 0.0, 0.0, OUTFLOW, STATIC_PRESSURE, 500, 0.0, 0.0, 0.0, 0.0 )
% -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------%
% Convective numerical method (SCALAR_UPWIND)
CONV_NUM_METHOD_TURB= SCALAR_UPWIND
% Time discretization (EULER_IMPLICIT)
TIME_DISCRE_TURB= EULER_IMPLICIT
% Reduction factor of the CFL coefficient in the turbulence problem
CFL_REDUCTION_TURB= 0.5
% ------------------------ SURFACES IDENTIFICATION ----------------------------%
% Marker of the surface which is going to be plotted or designed
MARKER_PLOTTING= ( INFLOW,WALL ,OUTFLOW,SYMMETRY)
% Marker of the surface where the functional (Cd, Cl, etc.) will be evaluated
MARKER_MONITORING= ( INFLOW,WALL ,OUTFLOW,SYMMETRY)
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
% Numerical method for spatial gradients (GREEN_GAUSS, LEAST_SQUARES,
% WEIGHTED_LEAST_SQUARES)
NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES
% Courant-Friedrichs-Lewy condition of the finest grid
CFL_NUMBER= 0.5
% Adaptive CFL number (NO, YES)
CFL_ADAPT= NO
% Parameters of the adaptive CFL number (factor down, factor up, CFL min value,
% CFL max value )
CFL_ADAPT_PARAM= ( 0.5, 1, 1.0, 100.0 )
% Runge-Kutta alpha coefficients
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% Linear solver for the implicit formulation (BCGSTAB, FGMRES)
LINEAR_SOLVER= BCGSTAB
% Min error of the linear solver for the implicit formulation
LINEAR_SOLVER_ERROR= 1E-6
% Max number of iterations of the linear solver for the implicit formulation
LINEAR_SOLVER_ITER= 5
% Preconditioner of the Krylov linear solver (ILU, LU_SGS, LINELET, JACOBI)
LINEAR_SOLVER_PREC= ILU
% Linael solver ILU preconditioner fill-in level (1 by default)
LINEAR_SOLVER_ILU_FILL_IN= 0
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC,
% TURKEL_PREC, MSW)
CONV_NUM_METHOD_FLOW= ROE
% Coefficient for the limiter (smooth regions)
VENKAT_LIMITER_COEFF= 0.006
% 2nd and 4th order artificial dissipation coefficients
JST_SENSOR_COEFF= ( 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT)
TIME_DISCRE_FLOW= EULER_IMPLICIT
% ----------- SLOPE LIMITER AND DISSIPATION SENSOR DEFINITION -----------------%
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations.
% Required for 2nd order upwind schemes (NO, YES)
MUSCL_FLOW= YES
% Slope limiter (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG,
% BARTH_JESPERSEN, VAN_ALBADA_EDGE)
SLOPE_LIMITER_FLOW= NONE
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations.
MUSCL_TURB= NO
% -------------------------- MULTIGRID PARAMETERS -----------------------------%
% Multi-Grid Levels (0 = no multi-grid)
MGLEVEL= 2
% Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE)
MGCYCLE= V_CYCLE
% Multi-grid pre-smoothing level
MG_PRE_SMOOTH= ( 1, 2, 3, 3 )
% Multi-grid post-smoothing level
MG_POST_SMOOTH= ( 0, 0, 0, 0 )
% Jacobi implicit smoothing of the correction
MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 )
% Damping factor for the residual restriction
MG_DAMP_RESTRICTION= 0.8
% Damping factor for the correction prolongation
MG_DAMP_PROLONGATION= 0.8
% ---------------- ADJOINT-FLOW NUMERICAL METHOD DEFINITION -------------------%
% Convective numerical method (JST, LAX-FRIEDRICH, ROE)
CONV_NUM_METHOD_ADJFLOW= ROE
% Monotonic Upwind Scheme for Conservation Laws (TVD) in the adjoint flow equations.
MUSCL_ADJFLOW= YES
% Slope limiter (NONE, VENKATAKRISHNAN, BARTH_JESPERSEN, VAN_ALBADA_EDGE,
% SHARP_EDGES, WALL_DISTANCE)
SLOPE_LIMITER_ADJFLOW= NONE
% 2nd, and 4th order artificial dissipation coefficients
ADJ_JST_SENSOR_COEFF= ( 0.5, 0.02 )
% Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT)
TIME_DISCRE_ADJFLOW= EULER_IMPLICIT
% Relaxation coefficient
RELAXATION_FACTOR_ADJOINT= 1.0
% Reduction factor of the CFL coefficient in the adjoint problem
CFL_REDUCTION_ADJFLOW= 0.8
% Limit value for the adjoint variable
LIMIT_ADJFLOW= 1E15
% Multigrid adjoint problem (NO, YES)
MG_ADJFLOW= NO
% Objective function in gradient evaluation (DRAG, LIFT, SIDEFORCE, MOMENT_X,
% MOMENT_Y, MOMENT_Z, EFFICIENCY,
% EQUIVALENT_AREA, NEARFIELD_PRESSURE,
% FORCE_X, FORCE_Y, FORCE_Z, THRUST,
% TORQUE, FREE_SURFACE, TOTAL_HEATFLUX,
% MAXIMUM_HEATFLUX, INVERSE_DESIGN_PRESSURE,
% INVERSE_DESIGN_HEATFLUX, SURFACE_TOTAL_PRESSURE,
% SURFACE_MASSFLOW)
% For a weighted sum of objectives: separate by commas, add OBJECTIVE_WEIGHT and MARKER_MONITORING in matching order.
OBJECTIVE_FUNCTION = SURFACE_MACH
% List of weighting values when using more than one OBJECTIVE_FUNCTION. Separate by commas and match with MARKER_MONITORING.
OBJECTIVE_WEIGHT= -1.0E-7,1.0
% Marker on which to track one-dimensionalized quantities
MARKER_ANALYZE = (WALL)
% Method to compute the average value in MARKER_ANALYZE (AREA, MASSFLUX).
MARKER_ANALYZE_AVERAGE = AREA
% --------------------------- CONVERGENCE PARAMETERS --------------------------%
% Number of total iterations
ITER= 100
% Convergence criteria (CAUCHY, RESIDUAL)
CONV_CRITERIA= RESIDUAL
% Min value of the residual (log10 of the residual)
CONV_RESIDUAL_MINVAL= -24
% Start convergence criteria at iteration number
CONV_STARTITER= 10
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
% Mesh input file
MESH_FILENAME= half_nozzle6.su2
% Mesh input file format (SU2, CGNS)
MESH_FORMAT= SU2
% Mesh output file
MESH_OUT_FILENAME= mesh_out.su2
% Restart flow input file
SOLUTION_FILENAME= solution_flow.dat
% Restart adjoint input file
SOLUTION_ADJ_FILENAME= solution_adj.dat
% Output file format (TECPLOT, TECPLOT_BINARY, PARAVIEW, PARAVIEW_BINARY,
% FIELDVIEW, FIELDVIEW_BINARY)
TABULAR_FORMAT= CSV
% Output file convergence history (w/o extension)
CONV_FILENAME= history
% Output file restart flow
RESTART_FILENAME= restart_flow.dat
% Output file flow (w/o extension) variables
VOLUME_FILENAME= flow
% Output file restart adjoint
RESTART_ADJ_FILENAME= restart_adj.dat
% Output file adjoint (w/o extension) variables
VOLUME_ADJ_FILENAME= adjoint
% Output Objective function gradient (using continuous adjoint)
GRAD_OBJFUNC_FILENAME= of_grad.dat
% Output file surface flow coefficient (w/o extension)
SURFACE_FILENAME= surface_flow
% Output file surface adjoint coefficient (w/o extension)
SURFACE_ADJ_FILENAME= surface_adjoint
% Writing solution file frequency
OUTPUT_WRT_FREQ= 1000
% Screen output
SCREEN_OUTPUT= (INNER_ITER, RMS_DENSITY, RMS_TKE, RMS_DISSIPATION, CL,CD)
% Output files
OUTPUT_FILES = (RESTART, PARAVIEW, SURFACE_PARAVIEW, SURFACE_CSV)
% -------------------- FREE-FORM DEFORMATION PARAMETERS -----------------------%
% Tolerance of the Free-Form Deformation point inversion
FFD_TOLERANCE= 1E-10
% Maximum number of iterations in the Free-Form Deformation point inversion
FFD_ITERATIONS= 500
% FFD box definition: 3D case (FFD_BoxTag, X1, Y1, Z1, X2, Y2, Z2, X3, Y3, Z3, X4, Y4, Z4,
% X5, Y5, Z5, X6, Y6, Z6, X7, Y7, Z7, X8, Y8, Z8)
% 2D case (FFD_BoxTag, X1, Y1, 0.0, X2, Y2, 0.0, X3, Y3, 0.0, X4, Y4, 0.0,
% 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
FFD_DEFINITION= (MAIN_BOX, -0.04, 0.01, 0, 0.04, 0.01, 0, 0.04, 0.05, 0, -0.04, 0.05, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0)
% FFD box degree: 3D case (x_degree, y_degree, z_degree)
% 2D case (x_degree, y_degree, 0)
FFD_DEGREE= (12, 1,0)
% Surface continuity at the intersection with the FFD (1ST_DERIVATIVE, 2ND_DERIVATIVE)
FFD_CONTINUITY= 2ND_DERIVATIVE
% ------------------------ GRID DEFORMATION PARAMETERS ------------------------%
% Kind of deformation (FFD_SETTING, HICKS_HENNE, HICKS_HENNE_NORMAL, PARABOLIC,
% HICKS_HENNE_SHOCK, NACA_4DIGITS, DISPLACEMENT, ROTATION,
% FFD_CONTROL_POINT, FFD_DIHEDRAL_ANGLE, FFD_TWIST_ANGLE,
% FFD_ROTATION)
% Marker of the surface in which we are going apply the shape deformation
DV_MARKER= ( WALL)
DV_KIND= FFD_CONTROL_POINT_2D
% Parameters of the shape deformation
% - HICKS_HENNE_FAMILY ( Lower(0)/Upper(1) side, x_Loc )
% - NACA_4DIGITS ( 1st digit, 2nd digit, 3rd and 4th digit )
% - PARABOLIC ( 1st digit, 2nd and 3rd digit )
% - DISPLACEMENT ( x_Disp, y_Disp, z_Disp )
% - FFD_CONTROL_POINT ( FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Disp, y_Disp, z_Disp )
% - ROTATION ( x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
DV_PARAM= (MAIN_BOX, 6,0, 0,0,1.0,0 )
% Value of the shape deformation deformation
DV_VALUE= 0.0
% Number of smoothing iterations for FEA mesh deformation
DEFORM_LINEAR_SOLVER_ITER= 500
% Number of nonlinear deformation iterations (surface deformation increments)
DEFORM_NONLINEAR_ITER= 1
% Print the residuals during mesh deformation to the console (YES, NO)
DEFORM_CONSOLE_OUTPUT= YES
% Minimum residual criteria for the linear solver convergence of grid deformation
DEFORM_LINEAR_SOLVER_ERROR= 1E-14
% Type of element stiffness imposed for FEA mesh deformation (INVERSE_VOLUME,
% WALL_DISTANCE, CONSTANT_STIFFNESS)
DEFORM_STIFFNESS_TYPE= WALL_DISTANCE
% --------------------- OPTIMAL SHAPE DESIGN DEFINITION -----------------------%
% Available flow based objective functions or constraint functions
% DRAG, LIFT, SIDEFORCE, EFFICIENCY, BUFFET,
% MOMENT_X, MOMENT_Y, MOMENT_Z,
% THRUST, TORQUE, FIGURE_OF_MERIT,
% TOTAL_HEATFLUX, MAXIMUM_HEATFLUX,
% INVERSE_DESIGN_PRESSURE, INVERSE_DESIGN_HEATFLUX,
% SURFACE_TOTAL_PRESSURE, SURFACE_MASSFLOW
% SURFACE_STATIC_PRESSURE, SURFACE_MACH
% Available geometrical based objective functions or constraint functions
% AIRFOIL_AREA, AIRFOIL_THICKNESS, AIRFOIL_CHORD, AIRFOIL_TOC, AIRFOIL_AOA,
% WING_VOLUME, WING_MIN_THICKNESS, WING_MAX_THICKNESS, WING_MAX_CHORD, WING_MIN_TOC, WING_MAX_TWIST, WING_MAX_CURVATURE, WING_MAX_DIHEDRAL
% STATION#_WIDTH, STATION#_AREA, STATION#_THICKNESS, STATION#_CHORD, STATION#_TOC,
% STATION#_TWIST (where # is the index of the station defined in GEO_LOCATION_STATIONS)
% Available design variables
% 2D Design variables
% FFD_CONTROL_POINT_2D ( 19, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, x_Mov, y_Mov )
% FFD_CAMBER_2D ( 20, Scale | Mark. List | FFD_BoxTag, i_Ind )
% FFD_THICKNESS_2D ( 21, Scale | Mark. List | FFD_BoxTag, i_Ind )
% FFD_TWIST_2D ( 22, Scale | Mark. List | FFD_BoxTag, x_Orig, y_Orig )
% HICKS_HENNE ( 30, Scale | Mark. List | Lower(0)/Upper(1) side, x_Loc )
% ANGLE_OF_ATTACK ( 101, Scale | Mark. List | 1.0 )
% 3D Design variables
% FFD_CONTROL_POINT ( 11, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind, k_Ind, x_Mov, y_Mov, z_Mov )
% FFD_NACELLE ( 12, Scale | Mark. List | FFD_BoxTag, rho_Ind, theta_Ind, phi_Ind, rho_Mov, phi_Mov )
% FFD_GULL ( 13, Scale | Mark. List | FFD_BoxTag, j_Ind )
% FFD_CAMBER ( 14, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind )
% FFD_TWIST ( 15, Scale | Mark. List | FFD_BoxTag, j_Ind, x_Orig, y_Orig, z_Orig, x_End, y_End, z_End )
% FFD_THICKNESS ( 16, Scale | Mark. List | FFD_BoxTag, i_Ind, j_Ind )
% FFD_ROTATION ( 18, Scale | Mark. List | FFD_BoxTag, x_Axis, y_Axis, z_Axis, x_Turn, y_Turn, z_Turn )
% FFD_ANGLE_OF_ATTACK ( 24, Scale | Mark. List | FFD_BoxTag, 1.0 )
% Global design variables
% TRANSLATION ( 1, Scale | Mark. List | x_Disp, y_Disp, z_Disp )
% ROTATION ( 2, Scale | Mark. List | x_Axis, y_Axis, z_Axis, x_Turn, y_Turn, z_Turn )
% Optimization objective function with scaling factor, separated by semicolons.
% To include quadratic penalty function: use OPT_CONSTRAINT option syntax within the OPT_OBJECTIVE list.
% ex= Objective * Scale
OPT_OBJECTIVE= SURFACE_MACH
% Optimization constraint functions with pushing factors (affects its value, not the gradient
% in the python scripts), separated by semicolons
% ex= (Objective = Value ) * Scale, use '>','<','='
OPT_CONSTRAINT= NONE
% Factor to reduce the norm of the gradient (affects the objective function and gradient in the python scripts)
% In general, a norm of the gradient ~1E-6 is desired.
OPT_GRADIENT_FACTOR= 1E-6
% Factor to relax or accelerate the optimizer convergence (affects the line search in SU2_DEF)
% In general, surface deformations of 0.01'' or 0.0001m are desirable
OPT_RELAX_FACTOR= 1E3
% Maximum number of optimizer iterations
OPT_ITERATIONS= 100
% Requested accuracy
OPT_ACCURACY= 1E-10
% Upper bound for each design variable
OPT_BOUND_UPPER= 0.020
% Lower bound for each design variable
OPT_BOUND_LOWER= -0.020
% Optimization design variables, separated by semicolons
DEFINITION_DV= ( 19, 1.0| WALL| MAIN_BOX, 1,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 2,1,0,1.0);( 19, 1.0| WALL| MAIN_BOX, 3,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 4,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 5,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 6,1,0,1.0);( 19, 1.0| WALL| MAIN_BOX, 7,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 8,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 9,1,0,1.0);( 19, 1.0| WALL | MAIN_BOX, 10,1,0,1.0)
abk1234 is offline   Reply With Quote
Inverse Design Optimization khavart SU2 Shape Design 0 June 20, 2019 03:37
Benchmark Optimization Study for SU2 Buxwax SU2 6 March 28, 2019 08:10
SU2 for nozzle simulations blais.bruno SU2 1 October 31, 2017 15:15
SU2 Shape optimization questions AdriC SU2 Shape Design 6 January 27, 2016 04:25
Question about SU2 optimization YoniHe SU2 Shape Design 3 January 15, 2016 00:31
