Home > Forums > Software User Forums > SU2
Freestream initialization in compressible flow
Like Tree1Likes
  • 1 Post By pdp.aero
Old   October 7, 2021, 05:00
Default Freestream initialization in compressible flow
Arijit Saha
ari003 is on a distinguished road
Hi SU2 user,
This might be a lame doubt to ask for but somehow if I could get some understanding it will be of great help.
I am simulating an airfoil with M=0.8 and below are my freestream parameters
M=0.8,
Stagnation or total pressure (P0)= 101325 Pa,
Static pressure= 66486.2
Stagnation Temperature(T0)= 297 K,
Static temperature= 263.3 K
Now applying the ideal gas law
Stagnation density= P0/(R*T0)= 1.188
Similarly static density = 0.875
Dynamic viscosity (Sutherland on)= 1.81 E-5
Now as per my knowledge the Reynolds number should be based on the static values which gives = 1.335 E7
Now my doubt is the Freestream Pressure or Temperature in the cfg file should be the stagnation or static one?
If I put Stagnation
Pressure, Temp and density all will be stagnation one and den how will the Reynolds no. of the freestream be calculated?
MACH_NUMBER= 0.8
% Angle of attack (degrees, only for compressible flows)
AOA= 0.0
% Init option to choose between Reynolds (default) or thermodynamics quantities
% for initializing the solution (REYNOLDS, TD_CONDITIONS)
INIT_OPTION= REYNOLDS
% De-Dimensionalization
REF_DIMENSIONALIZATION = DIMENSIONAL
FREESTREAM_OPTION= TEMPERATURE_FS
% Free-stream temperature (288.15 K by default)
FREESTREAM_TEMPERATURE= 297
% Reynolds number (non-dimensional, based on the free-stream values)
REYNOLDS_NUMBER= 1.335e+7
% Reynolds length (1 m by default)
REYNOLDS_LENGTH= 1.0
% --------------------------- VISCOSITY MODEL ---------------------------------%
% Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY).
VISCOSITY_MODEL= SUTHERLAND
% Molecular Viscosity that would be constant (1.716E-5 by default)
MU_CONSTANT= 1.716e-05
This is the cfg file I was using but the physics of the freestream case will be wrong if I proceed with this. Because the density is calculated from Reynolds which gives the static density. Now the pressure is calculated from the ideal gas law employing the Temp(stagnation) specified and the density (static) obtained which simply cant be made to done.
So, what will be the right way to define my freestream condition?
Thanks .
ari003 is offline   Reply With Quote
Old   October 7, 2021, 13:32
Pay D.
pdp.aero is on a distinguished road
This might help:
https://arc.aiaa.org/doi/10.2514/6.2013-287
ari003 likes this.
since every contribution counts, always good ones are appreciated!
pdp.aero is offline   Reply With Quote
Old   October 7, 2021, 15:40
Arijit Saha
Originally Posted by pdp.aero View Post
Thanks for your generous response. Somehow I figured out that the freestream values should be static one and not the stagnation values.
Intuition for why flow follows convex surfaces lopp Main CFD Forum 47 February 1, 2022 13:14
VOF compressible two-phase flow lzhaok6 Fluent Multiphase 0 August 17, 2020 17:17
Mass flow rate / stagnation of an unchoked nozzle placed in freestream mlazim14 Main CFD Forum 6 April 19, 2020 21:40
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
Solving unsteady compressible low speed flow atit Main CFD Forum 8 July 31, 2000 13:19
