Home > Forums > Software User Forums > SU2
Stable solution in version 7.0.0, diverging in 7.2.0
Old   January 19, 2022, 10:13
Default Stable solution in version 7.0.0, diverging in 7.2.0
Dónal McCaughey
Dónal is on a distinguished road
I am running a compressible (M=2.5) simulation in SU2 version 7.0.0. In 7.0.0 I am able to get a stable solution running for 1000s of iterations and residuals approach 10^-3. When I try running the simulation in version 7.2.0 it diverges after a small number of iterations. The number of iterations varies with CFL, less than 10 with a CFL of 5 and around 60 with a CFL of 0.05.
I suspect the issue is related to the mesh quality. The model has some sharp edges where small angles and high volume ratios are difficult to avoid. I'm not sure why this would be an issue with the most recent version and not a previous one. I have tried different slope limiters and solvers but the solution still diverges.
Looking at the solution after this short number of iterations, it appears to have just populated the mesh with the freestream values and nothing else.
Any ideas on why this may be happening, or version differences that might be related to this would be greatly appreciated
Medium722.txt
Dónal is offline   Reply With Quote
Old   January 19, 2022, 19:06
pcg
Pedro Gomes
pcg is on a distinguished road
At some point we fixed a bug that was freezing the solution in places where the rate of change of the solution was too high.
It was a kind of deadlock between turbulence and mean flow logic that caused the automatic relaxation factor to never increase, and so if it went to zero at any point...
This was probably saving your case, I would try running 1st order first to get rid of initial transients.
pcg is offline   Reply With Quote
diverging, su2, update
Solution diverging after updating from 7.0.0 to 7.1.1 Dónal SU2 1 September 8, 2021 05:07
NACA0012 validation with different OF version Ivangzp OpenFOAM Running, Solving & CFD 0 February 17, 2021 11:34
Different version of Fluent, different solution! Kim yongchul FLUENT 2 January 14, 2021 00:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
HELP! Diverging Solution for Incompressible Prob. Bob FLUENT 3 April 16, 2006 19:33
