Rep Power: 7 ![]() |
hi,
I am using SU2 for quite a long time and in my experience, I find the case is easily to diverge when the muscl interpolation in turb equation is used. It is rare in 2-D cases and common in 3-D case, no matter how much the CFL number is, whether the turb model is SA or SST, which MUSCL reconstruction method is. Even if the case can meet convergence criteria with MUSCL_TURB= NO So I wonder if I miss sth. important for the robustness. The below options are what I usually set. NUM_METHOD_GRAD= GREEN_GAUSS NUM_METHOD_GRAD_RECON = GREEN_GAUSS CFL_NUMBER= 5 MUSCL_FLOW= YES SLOPE_LIMITER_FLOW= VENKATAKRISHNAN MUSCL_TURB= YES SLOPE_LIMITER_TURB= VENKATAKRISHNAN Any help would be appreciated. |
Pedro Gomes
Rep Power: 14 ![]() |
I think VENKATAKRISHNAN_WANG would be a better choice because the range of the turbulence variables is very different from the flow variables.
The typical value of the VENKAT_LIMITER_COEFF (0.05) basically means that the SA model would be unlimited (since nu-tilde is of the order of a viscosity). You can also try using SA_NEG instead of SA. For SST I think it is going to be harder... Omega has very large gradients close to walls. |
Thanks for your help.
I have tried to lower the value of k and omega (It seems k is more easily to get a negative value using muscl than omega in my current case) in SST with using REF_DIMENSIONALIZATION= FREESTREAM_PRESS_EQ_ONE option, and it runs well with BARTH_JESPERSEN limiter in a 3-D case. However, it is not easy to judge the convergence by the performance of RMS when the non_dim turns on. So I wonder if the non_dim of k and omega can be apart from the euler equation. Also, I notice that the non-dim method of k/omega/mu_l/mu_t in su2 is as below: mu_l_ref = rho_ref * vel_ref * l_ref mu_t_ref = mu_l_ref k_ref = vel_ref^2 omega_ref = k_ref * rho_ref /mu_t_ref As a matter of fact, CFL3D shows as below: mu_l_ref = mu_l_farfield mu_t_ref = mu_l_ref k_ref = vel_ref^2 omega_ref = Re * vel_ref/ l_ref = k_ref * rho_ref /mu_t_ref The latter method could get a lower omega and k nearwall by lower mu_l_ref and may be better. Actually I am thinking to do this job but I am not fully aware of the influence to other part of codes of this change. Shall I do this change? |
Display Modes | |
Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 27 | May 19, 2022 04:19 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Riemann invariants of adjoint equations of shallow water equations | zqb0929 | Main CFD Forum | 0 | March 15, 2012 01:54 |
CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 15:21 |
? fluctuating equations for homogenous shear turb. | ff_fan | Main CFD Forum | 1 | September 20, 2002 08:39 |
