How to explain the lift force in SU2's source code? |
October 10, 2022, 23:27 |
Jay Wee
Rep Power: 3 |
I know the drag always aligns with the freestream direction, so it is quite easy to compute drag by:
drag = <total force vector> * <unit vector of freestream direction> However, the lift force's direction is not obvious. I think the lift formula should be <lift vector> = <total force vector> - drag * <unit vector of freestream direction> then the magnitude of lift could be got by lift = sqrt(<lift vector> * <lift vector>), which is a complex formula. But in the SU2's code, the lift formula is very simple: (click here to check source code: https://github.com/su2code/SU2/blob/...Base.inl#L1979) InvCoeff.CL[iMarker] = -ForceInviscid[0] * sin(Alpha) + ForceInviscid[2] * cos(Alpha); It looks strange to me, b/c lift has no dependence on Beta. Anyone could help to explain or post some reference link? Thanks. Last edited by jaywee; October 11, 2022 at 08:17. |
October 22, 2022, 12:59 |
Ercan Umut
Rep Power: 3 |
As a graduate student I am really not sure about this but I guess they are taking normal and axial force's coefficients and using them on the lift and drag calculations. When I first saw the eqns. in code I tought they reminded me of something and found them on the Anderson's Fundamentals of Aerodynamics book. I attached 2 pictures as reference. In my opinion, they are not as easy as they look, at first glance at least you get to used to them in time.
October 23, 2022, 20:38 |
Pedro Gomes
Rep Power: 13 |
The result of <force vector> - drag * <drag direction> is not the lift vector, but rather lift + sideforce
lift, source code, su2 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
