Home > Forums > Software User Forums > SU2
Problem on Nasa stage 35 simulation using su2 7.3.1
Old   April 17, 2022, 22:57
Default Problem on Nasa stage 35 simulation using su2 7.3.1
Kyle
wkholy is on a distinguished road
I tried to simulate Nasa stage 35 using su2 7.3.1.
It can run in first 10 steps when the rotational speed is set much smaller. However, it will get NaN for residual computation when the rotational speed gets larger.
Error in "void CSolver::SetResidual_RMS(const CGeometry*, const CConfig*)":
SU2 has diverged (NaN detected).
------------------------------ Error Exit -------------------------------
Please see the attachment for the settings.
Hope it can be resolved.
wkholy is offline   Reply With Quote
Old   May 27, 2022, 09:51
koray is on a distinguished road
Hi Kyle. I think your setup is ok. Is it possible for you to solve both rotor and stator separately first and then solve it together starting from the converged data. Convergence of compressor flows are very sensitive to initial data thanks to complex 3D flow field and adverse pressure gradients. With the same logic, you may want to keep CFL low along the computation. And I suppose your mesh is ok. Good luck.
koray is offline   Reply With Quote
Old   May 29, 2022, 21:37
Kyle
Thanks, Koray. I have successfully run the case. Just the efficiency cannot converge but increase to 1000 and more. I have tried the tutorial case. Yet the efficiency is not stable as I change the time step from 3000 to 5000. SU2 CFD version is 7.3.1.
Old   September 28, 2022, 09:02
Ashvin
ashvin is on a distinguished road
Hello Kyle,
I stumbled upon this thread looking for why my efficiency values are all zero in my history.csv for my rotor37 case. I am using V740 and I am trying to figure out how to get efficiency data in history.csv file. Is there an option I need to add in SU2 card?
Thanks
Ashvin
ashvin is offline   Reply With Quote
Old   September 29, 2022, 04:10
Kyle
Originally Posted by ashvin View Post
Hello Kyle,
Thanks
Ashvin
Hi, Ashvin. I think the 7 version of SU2 cannot directly output turbo parameters in history.csv. But you can conveniently revise output_physics.cpp for a new output file of turbo efficiency or collect screen output and extract the turbo data using python. If the optimization is your goal, then SU2 version 7 can only deal with single zone problem of turbomachinery from my understanding.
Old   October 21, 2022, 08:07
Ashvin
Hello Kyle,
Thanks! I will work on that! I am only using SU2 to perform the CFD solutions.
Thanks
Ashvin
Simulation of UAV rotor using SU2 rotating frame Drapier SU2 0 June 14, 2017 05:26
RFR Gear Simulation Problem JBirks92 CFX 7 April 11, 2017 19:25
Problem storing values at UDM for tranisient dynamic mesh simulation xab Fluent UDF and Scheme Programming 4 December 22, 2016 04:10
Problem in initializing transient simulation with a finer mesh sidd CFX 8 April 29, 2016 02:25
Dynamic mesh simulation (pimpleDyMFoam) problem sidlof OpenFOAM Running, Solving & CFD 6 April 12, 2013 11:24
