Exit Profile BC
I wish to apply a static pressure profile BC at the outlet (which I am having from experiment). Is there anything similar to the 'specified inlet profile' option? Thank you. Regards, Jyoti |
No, at the moment you cannot specify a profile at the outlet.
If you are in for some small programming you can do this: In the function BC_Outlet in the file CIncEulerSolver for incompressible flow, it checks if you have a pressure outlet. You could replace the constant value of outlet pressure in the line Code:
P_Outlet = config->GetOutlet_Pressure(Marker_Tag)/config->GetPressure_Ref(); with some array with values that you define, or a function depending on the coordinates. |
I was going through the CTurbSSTSolver and CTurbSASolver routines, as my problem is a viscous, compressible one. I was going through the inlet profile portion therein and found that a bit involved and was so wondering about the possibility of any pre-existing exit profile BC. Thanks again. Regards, Jyoti |
