July 14, 2022, 04:34 |
Volumetric flow rate
Praveen
Rep Power: 3 |
Hey, everyone I am currently dealing with a case where I have been provided with only the volumetric flow rate through an inlet.(no velocity or area description).
I want to use this as BC for the inlet in SU2 but there is no volumetric flow BC in SU2. I checked and there is only mass flow case where I need the velocity at the inlet. I know the density is there any way I can provide this boundary condition without further information. Thanks in advance. |
July 16, 2022, 02:26 |
bigfoot
No, you need the surface area to compute the velocity. You'll need to compute the surface area from the geometry information
Outlet BC: fixed outlet volumetric flow rate with reversed flow | juanf | OpenFOAM Pre-Processing | 0 | July 29, 2021 06:17 |
rhoSimpleFoam with specified mass flow rate at outlet | ishan_ae | OpenFOAM Running, Solving & CFD | 3 | September 1, 2020 01:11 |
Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 10:20 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 17:46 |
