SU2 NACA0012 Transitional flow simulation Convergence Issues
1 Attachment(s)
Hey,
I am attempting to simulate a 2D NACA0012 aerofoil using the SU2 SA BC-transitional model under low Re, incompressible flow with the following conditions below, an image of the SU2 setup printout is also attached to this post: Re = 3e5 Density = 1.225 kg/m^3 Velocity = 4.38 m/s at zero angle of attack Viscosity = 1.789e-05 Chord Length = 1m The purpose is to evaluate CD, CL and transition location along the aerofoil chord. However the simulation struggles to converge, Below is a list of parameters I have tested to attempt to gain convergence, Fixed CFL: Ran at values ranging from 0.2 to 50 with no success. Adaptive CFL: Resulted in residual oscillations of RMS values. Multigrid: Ran at MGLEVEL of 0,2,3 testing V_CYCLE and W_CYCLE resulted in divergence occurring. I was wondering how I can help improve the convergence, thanks in advance for any suggestions on how to do so. Mesh: Mesh used for this simulation was taken from the Turbulent NACA0012 SU2 tutorial Link: https://su2code.github.io/tutorials/...lent_NACA0012/ SU2 cfg below: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % % % SU2 configuration file % % Case description: 2D NACA 0012 Airfoil SA BC Transitional model % % Author: -- % Date: -- % % File Version 7.3.1 "Blackbird" % % % %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% % ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------% % % Physical governing equations (EULER, NAVIER_STOKES, % WAVE_EQUATION, HEAT_EQUATION, FEM_ELASTICITY, % POISSON_EQUATION) SOLVER= INC_RANS % % Specify turbulent model (NONE, SA, SA_NEG, SST) KIND_TURB_MODEL= SA % %Specify transition model (NONE, LM, BC) KIND_TRANS_MODEL= BC FREESTREAM_TURBULENCEINTENSITY = 0.0007 % % Mathematical problem (DIRECT, CONTINUOUS_ADJOINT) MATH_PROBLEM= DIRECT % % Restart solution (NO, YES) RESTART_SOL= NO % -------------------- INCOMPRESSIBLE FREE-STREAM DEFINITION ------------------% % % Free-stream density (1.2886 Kg/m^3 (air), 998.2 Kg/m^3 (water)) INC_DENSITY_INIT= 1.225 % % Initial velocity for incompressible flows (1.0,0,0 m/s by default) % % AoA 0.0 deg INC_VELOCITY_INIT= ( 4.38, 0.0, 0.0 ) % % Non-dimensionalization scheme for incompressible flows. Options are % INITIAL_VALUES (default), REFERENCE_VALUES, or DIMENSIONAL. % INC_*_REF values are ignored unless REFERENCE_VALUES is chosen. INC_NONDIM= DIMENSIONAL % % Reference density for incompressible flows (1.0 kg/m^3 by default) INC_DENSITY_REF= 1.0 % % Reference velocity for incompressible flows (1.0 m/s by default) INC_VELOCITY_REF= 1.0 % % Reference temperature for incompressible flows that include the % energy equation (1.0 K by default) INC_TEMPERATURE_REF = 1.0 % --------------------------- VISCOSITY MODEL ---------------------------------% % % Viscosity model (SUTHERLAND, CONSTANT_VISCOSITY). VISCOSITY_MODEL= CONSTANT_VISCOSITY % % Molecular Viscosity that would be constant (1.716E-5 by default) MU_CONSTANT= 1.789e-05 % ---------------------- REFERENCE VALUE DEFINITION ---------------------------% % % Reference origin for moment computation REF_ORIGIN_MOMENT_X = 0.25 REF_ORIGIN_MOMENT_Y = 0.00 REF_ORIGIN_MOMENT_Z = 0.00 % % Reference length for pitching, rolling, and yawing non-dimensional moment REF_LENGTH= 1.0 % % Reference area for force coefficients (0 implies automatic calculation) REF_AREA= 0 % -------------------- BOUNDARY CONDITION DEFINITION --------------------------% % % Navier-Stokes wall boundary marker(s) (NONE = no marker) MARKER_HEATFLUX= ( airfoil, 0.0 ) % % Farfield boundary marker(s) (NONE = no marker) MARKER_FAR= ( farfield ) % % Marker(s) of the surface to be plotted or designed MARKER_PLOTTING= ( airfoil ) % % Marker(s) of the surface where the functional (Cd, Cl, etc.) will be evaluated MARKER_MONITORING= ( airfoil ) % ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------% % % Numerical method for spatial gradients (GREEN_GAUSS, WEIGHTED_LEAST_SQUARES) NUM_METHOD_GRAD= GREEN_GAUSS % % Courant-Friedrichs-Lewy condition of the finest grid CFL_NUMBER= 10 % % Adaptive CFL number (NO, YES) CFL_ADAPT= NO % % Parameters of the adaptive CFL number (factor down, factor up, CFL min value, % CFL max value ) CFL_ADAPT_PARAM= ( 0.1, 1.2, 5, 1E3 ) % % Maximum Delta Time in local time stepping simulations MAX_DELTA_TIME= 1e6 % % Runge-Kutta alpha coefficients RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 ) % % Number of total iterations ITER= 800000 % ----------------------- SLOPE LIMITER DEFINITION ----------------------------% % % Coefficient for the limiter VENKAT_LIMITER_COEFF= 0.01 % % Coefficient for the sharp edges limiter ADJ_SHARP_LIMITER_COEFF= 3.0 % % Reference coefficient (sensitivity) for detecting sharp edges. REF_SHARP_EDGES= 3.0 % % Remove sharp edges from the sensitivity evaluation (NO, YES) SENS_REMOVE_SHARP= NO % % Slope limiter for species equations (NONE, VENKATAKRISHNAN, VENKATAKRISHNAN_WANG, BARTH_JESPERSEN, VAN_ALBADA_EDGE) SLOPE_LIMITER_SPECIES = VENKATAKRISHNAN % ------------------------ LINEAR SOLVER DEFINITION ---------------------------% % % Linear solver for implicit formulations (BCGSTAB, FGMRES) LINEAR_SOLVER= FGMRES % % Preconditioner of the Krylov linear solver (JACOBI, LINELET, LU_SGS) LINEAR_SOLVER_PREC= ILU % % Linael solver ILU preconditioner fill-in level (0 by default) LINEAR_SOLVER_ILU_FILL_IN= 0 % % Minimum error of the linear solver for implicit formulations LINEAR_SOLVER_ERROR= 1E-10 % % Max number of iterations of the linear solver for the implicit formulation LINEAR_SOLVER_ITER= 10 % -------------------------- MULTIGRID PARAMETERS -----------------------------% % % Multi-Grid Levels (0 = no multi-grid) MGLEVEL= 0 % % Multi-grid cycle (V_CYCLE, W_CYCLE, FULLMG_CYCLE) MGCYCLE= W_CYCLE % % Multi-grid pre-smoothing level MG_PRE_SMOOTH= ( 1, 2, 3, 3 ) % % Multi-grid post-smoothing level MG_POST_SMOOTH= ( 1, 1, 1, 1 ) % % Jacobi implicit smoothing of the correction MG_CORRECTION_SMOOTH= ( 0, 0, 0, 0 ) % % Damping factor for the residual restriction MG_DAMP_RESTRICTION= 0.75 % % Damping factor for the correction prolongation MG_DAMP_PROLONGATION= 0.75 % -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------% % % Convective numerical method (JST, LAX-FRIEDRICH, CUSP, ROE, AUSM, HLLC, % TURKEL_PREC, MSW) CONV_NUM_METHOD_FLOW= JST % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the flow equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_FLOW= YES % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_FLOW= VENKATAKRISHNAN % % 2nd and 4th order artificial dissipation coefficients JST_SENSOR_COEFF= ( 0.5, 0.02 ) % % Time discretization (RUNGE-KUTTA_EXPLICIT, EULER_IMPLICIT, EULER_EXPLICIT) TIME_DISCRE_FLOW= EULER_IMPLICIT % -------------------- TURBULENT NUMERICAL METHOD DEFINITION ------------------% % % Convective numerical method (SCALAR_UPWIND) CONV_NUM_METHOD_TURB= SCALAR_UPWIND % % Monotonic Upwind Scheme for Conservation Laws (TVD) in the turbulence equations. % Required for 2nd order upwind schemes (NO, YES) MUSCL_TURB= NO % % Slope limiter (VENKATAKRISHNAN, MINMOD) SLOPE_LIMITER_TURB= VENKATAKRISHNAN % % Time discretization (EULER_IMPLICIT) TIME_DISCRE_TURB= EULER_IMPLICIT % --------------------------- CONVERGENCE PARAMETERS --------------------------% % % Convergence criteria (CAUCHY, RESIDUAL) CONV_FIELD= RMS_PRESSURE % % Min value of the residual (log10 of the residual) CONV_RESIDUAL_MINVAL= -14 % % Start convergence criteria at iteration number CONV_STARTITER= 10 % % Number of elements to apply the criteria CONV_CAUCHY_ELEMS= 100 % % Epsilon to control the series convergence CONV_CAUCHY_EPS= 1E-6 % ------------------------- INPUT/OUTPUT INFORMATION --------------------------% % % Mesh input file MESH_FILENAME= n0012_2D.su2 % % Mesh input file format (SU2, CGNS, NETCDF_ASCII) MESH_FORMAT= SU2 % % Mesh output file MESH_OUT_FILENAME= mesh_out.su2 % % Restart flow input file SOLUTION_FILENAME= solution_flow.dat % % Restart adjoint input file SOLUTION_ADJ_FILENAME= solution_adj.dat % % Output file format (PARAVIEW, TECPLOT, STL) TABULAR_FORMAT= CSV % % Output file convergence history (w/o extension) CONV_FILENAME= history % % Output file restart flow RESTART_FILENAME= restart_flow.dat % % Output file restart adjoint RESTART_ADJ_FILENAME= restart_adj.dat % % Output file flow (w/o extension) variables VOLUME_FILENAME= flow % % Output file adjoint (w/o extension) variables VOLUME_ADJ_FILENAME= adjoint % % Output objective function gradient (using continuous adjoint) GRAD_OBJFUNC_FILENAME= of_grad.dat % % Output file surface flow coefficient (w/o extension) SURFACE_FILENAME= surface_flow % % Output file surface adjoint coefficient (w/o extension) SURFACE_ADJ_FILENAME= surface_adjoint % % Writing frequency for history output HISTORY_WRT_FREQ_INNER= 100 % HISTORY_WRT_FREQ_OUTER= 100 % HISTORY_WRT_FREQ_TIME= 100 % % Writing solution frequency OUTPUT_WRT_FREQ= 500 % % % Screen output SCREEN_OUTPUT = (INNER_ITER, WALL_TIME, RMS_PRESSURE, RMS_NU_TILDE, LIFT, DRAG) % % Volume output fields/groups (use 'SU2_CFD -d <config_file>' to view list of available fields) VOLUME_OUTPUT= (COORDINATES, SOLUTION, PRIMITIVE, INTERMITTENCY) % HISTORY_OUTPUT= ( ITER, TIME_DOMAIN, AOA, CFL_NUMBER, FLOW_COEFF, AERO_COEFF, RMS_RES ) |
