September 9, 2022, 07:06 |
Setting Different domain/zone
Antimo
Rep Power: 3 |
I am new on SU2, I try to simulate a field around an axisymmetric body. I have a mesh 3D with following zone "Farfield", "Body", "Outlet", "Symmetric plane". I setting my file .cfg and solve the field, when I postprocessing the data, the domain I see is unique, all zone is under "Zone 0" and I can't activate or deactivate the single zone. Is there an option to allow me to setting zone separate in file .cfg so I can see a single zone in postprocessing process? The mesh is an unstructured mesh build in ICEM CFD and the postprocessing program is Tecplot; there isn't a different law for the mesh, every zone and part have the same mesh. Thanks for your attention! |
September 11, 2022, 13:32 |
bigfoot
Rep Power: 17 |
I do not use tecplot, so I do not know what the limitations are here. However, if you save the results as PARAVIEW_MULTIBLOCK, then you get the separated zones in paraview.
September 12, 2022, 09:46 |
Antimo
Rep Power: 3 |
Thanks for your answer. I try it!
Fluent Parallelization Problem After AC Power Dropped | pawl | Hardware | 5 | November 13, 2016 06:08 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
