Philip Agenmonmen
Rep Power: 4 ![]() |
Hello all,
I’m currently struggling to get parallel computation to work through the installation guides. I am on a 2017 MacBook Pro, MacOS Monterey Version 12.6.2, Dual-Core Intel Core i5 processor. I attached an image of the number of processors section of my Hardware Overview . Doing a simulation with 1 core works fine but running a simulation with more than 1 core leads to the following error: SU2.EvaluationFailure: Path = /Users/PhilipAgenmonmen/Desktop/Year-4/Dissertation/Gmsh-SU2/NACA-0021/SU2/, Command = mpirun -n 2 /Users/PhilipAgenmonmen/Desktop/Year-4/Dissertation/Gmsh-SU2/NACA-0021/SU2/bin/SU2_CFD config_CFD.cfg SU2 process returned error '1' -------------------------------------------------------------------------- There are not enough slots available in the system to satisfy the 2 slots that were requested by the application: /Users/PhilipAgenmonmen/Desktop/Year-4/Dissertation/Gmsh-SU2/NACA-0021/SU2/bin/SU2_CFD Either request fewer slots for your application, or make more slots available for use. A "slot" is the Open MPI term for an allocatable unit where we can launch a process. The number of slots available are defined by the environment in which Open MPI processes are run: 1. Hostfile, via "slots=N" clauses (N defaults to number of processor cores if not provided) 2. The --host command line parameter, via a ":N" suffix on the hostname (N defaults to 1 if not provided) 3. Resource manager (e.g., SLURM, PBS/Torque, LSF, etc.) 4. If none of a hostfile, the --host command line parameter, or an RM is present, Open MPI defaults to the number of processor cores In all the above cases, if you want Open MPI to default to the number of hardware threads instead of the number of processor cores, use the --use-hwthread-cpus option. Alternatively, you can use the --oversubscribe option to ignore the number of available slots when deciding the number of processes to launch. -------------------------------------------------------------------------- Some things of note 1. I downloaded MPICH for the MPI version of SU2. However, I believe I now have both Open MPI & MPICH (when I do mpirun --version it says mpirun (Open MPI) 4.1.4). I haven't been able to find the location of Open MPI as I was thinking I may need to delete it. 2. At one point I edited the SU2_MPI_COMMAND in SU2's interface.py file to use 4 cores (oversubscribed or via use-hwthread-cpus). - However, this led to a recursive call of MPI and the file did not run Potentially my Mac has 2 cores when hyper-threaded and is already running in parallel? Any help would be much appreciated, Thanks, Philip |
#2 | |
bigfoot
Rep Power: 21 ![]() |
you can check with a command like 'lscpu' how many cpu's you can actually use (or System Report->Hardware ), just make sure the system reports what you expect (I guess 2).
There are some simple example programs to make sure that openmpi (or mpich) works correctly, e.g. here: https://docs.open-mpi.org/en/v5.0.x/validate.html# https://mpitutorial.com/tutorials/mpi-hello-world/ For mpich I actually use these compilation options: Code:
./meson.py build -Dwith-mpi=enabled -Dcustom-mpi=true -Dextra-deps=mpich Quote:
Can you verify your SU2 output? |
Philip Agenmonmen
Hey. Thanks for the information.
Here is my core & thread count: machdep.cpu.core_count: 2 machdep.cpu.thread_count: 4 I'm currently working on running test files with mpi and will update you on how that goes. One thing I wanted to mention is that I am using a pre-compiled SU2 MPI version and I don't have that meson.py file. Just to check, should I look to build a new SU2 from source? |
bigfoot
ok, I missed that you were using the precompiled SU2, my guess is that SU2 sees openmpi instead of mpich. It would be best if you can safely remove openmpi and install mpich only.
Philip Agenmonmen
That seems to have fixed things! Thank you very much. I can now run 2 cores!
I'll need to double-check but I don't think I can run 4 cores. This may be since the extra 2 are not physical. Uninstall I used point no. 3 in this post to uninstall openmpi for anyone else’s info. https://github.com/open-mpi/ompi/issues/600 |
Display Modes | |
Scaling of parallel computation? Solver/thread count combinations? | tdof | OpenFOAM | 8 | January 13, 2022 11:39 |
Any Procedure to setup parallel computation?? | fluidmechanics | SU2 Installation | 10 | July 21, 2017 04:31 |
Fluent parallel computation using Xeon duo-processor with CFD occupation below 50% | zhujj09 | FLUENT | 1 | October 19, 2016 15:02 |
FE-3.1 Parallel issues with BCs (gMax, reduce...) | Phicau | OpenFOAM Bugs | 2 | August 1, 2014 06:22 |
SU2 Tutorial 2 Parallel Computation | CrashLaker | SU2 | 7 | April 5, 2014 16:14 |
