Segmentation fault in SU2-NEMO
3 Attachment(s)
Hello everybody,
I hope you're spending same great time and not going to smash your heads against the wall, like myself, trying to figure out what's going on. I'm trying to use "nemo-euler" but keep getting immediately segmentation fault. If instead I use simply "euler" as solver everything goes smoothly, without errors. Anyone know what might be the error? I leave the config file and the error one, if they may help finding a solution. Thanks in advance for the help! P.S. edit I added also geo file, just in case. |
FLUID_MODEL= STANDARD_AIR is a no-go probably. See for example
https://github.com/su2code/SU2/blob/...wedge_ausm.cfg |
