Home > Forums > Software User Forums > SU2
Issue with N point error
Old   March 2, 2023, 11:18
Default Issue with N point error
Kamran
Kamranh01 is on a distinguished road
Hi, I seem to be getting an issue with my mesh involving an N-point error but every surface and volume has a physical surface/volume attached to it. I am very confused about how to rectify this error.
Any help would be massively appreciated
Kamranh01 is offline   Reply With Quote
Old   March 2, 2023, 11:19
Kamran
here is my gmsh file
// Gmsh project created on Mon Feb 27 15:44:12 2023
SetFactory("OpenCASCADE");
Merge "NACA 0012 CLOSED TRAILING EDGE.STEP";
Delete {
Volume{1};
Point(5) = {0, -3000, -650, 1.0};
Point(6) = {0, 3000, -650, 1.0};
Point(7) = {5196.15242271, 3000, 2350, 1.0};
Point(8) = {5196.15242271, -3000, 2350, 1.0};
Line(7) = {5, 6};
Line(8) = {8, 7};
Extrude {{0, 1, 0}, {0, 0, -650}, -2*Pi/3} {
Curve{8};
Line(12) = {5, 9};
Line(13) = {5, 8};
Line(14) = {6, 10};
Line(15) = {6, 7};
Curve Loop(6) = {14, -10, -15};
Plane Surface(6) = {6};
Curve Loop(7) = {12, -9, -13};
Plane Surface(7) = {7};
Curve Loop(8) = {13, 8, -15, -7};
Plane Surface(8) = {8};
Curve Loop(9) = {12, 11, -14, -7};
Plane Surface(9) = {9};
Surface Loop(2) = {5, 7, 9, 6, 8};
Volume(1) = {2};
Transfinite Curve {2, 4} = 200 Using Bump 1;
Transfinite Curve {1, 3} = 200 Using Progression 1;
Transfinite Surface {1};
Transfinite Surface {2};
Transfinite Curve {10, 9} = 30 Using Progression 1;
Transfinite Curve {11, 8} = 15 Using Progression 1;
Transfinite Curve {7} = 70 Using Bump 10;
Transfinite Curve {12} = 70 Using Progression 1.04;
Transfinite Curve {13} = 70 Using Progression 1.04;
Transfinite Curve {14} = 70 Using Progression 1.04;
Transfinite Curve {15} = 70 Using Progression 1.04;
Physical Surface("INLET", 16) = {6};
Physical Surface("OUTLET", 17) = {7};
Physical Surface("WALL", 18) = {5};
Physical Surface("SIDE_1", 19) = {8};
Physical Surface("SIDE_2", 20) = {9};
Physical Surface("BLADE", 21) = {1, 2, 3, 4};
Physical Volume("FLUID", 22) = {1};
Old   March 2, 2023, 11:21
Kamran
here is the config file I generated
% SU2 configuration file %
% Case description: NACA 0012 Rotor %
% Author:K.Hussain %
% Institution: University of Strathclyde %
% Date: Feb 28th, 2023 %
% File Version 7.5.1 "Blackbird" %
% ------------- DIRECT, ADJOINT, AND LINEARIZED PROBLEM DEFINITION ------------%
SOLVER= NAVIER_STOKES
KIND_TURB_MODEL= NONE
MATH_PROBLEM= DIRECT
RESTART_SOL= NO
SYSTEM_MEASUREMENTS= SI
% -------------------- COMPRESSIBLE FREE-STREAM DEFINITION --------------------%
MACH_NUMBER= 0.0
AOA= 7.0
FREESTREAM_PRESSURE= 101327.0
FREESTREAM_TEMPERATURE= 288.15
FREESTREAM_DENSITY= 1.225
FREESTREAM_OPTION= TEMPERATURE_FS
REYNOLDS_NUMBER= 165389.9181
REYNOLDS_LENGTH= 0.05
INIT_OPTION= TD_CONDITIONS
REF_DIMENSIONALIZATION= DIMENSIONAL
% ---------------------- REFERENCE VALUE DEFINITION ---------------------------%
REF_ORIGIN_MOMENT_X = 0.00
REF_ORIGIN_MOMENT_Y = 0.00
REF_ORIGIN_MOMENT_Z = -650.00
REF_LENGTH= 0.05
REF_AREA= 0
% --------------------------------- FLUID MODEL -----------------------------------%
FLUID_MODEL= IDEAL_GAS
GAMMA_VALUE= 1.4
GAS_CONSTANT= 287.06
% --------------------------- VISCOSITY MODEL ---------------------------------%
VISCOSITY_MODEL= SUTHERLAND
MU_CONSTANT= 1.716E-5
MU_REF= 1.716E-5
MU_T_REF= 273.15
SUTHERLAND_CONSTANT= 110.4
% -------------------- BOUNDARY CONDITION DEFINITION --------------------------%
MARKER_HEATFLUX= ( BLADE, 0.0 )
MARKER_FAR= ( WALL )
MARKER_INTERNAL= ( BLADE )
MARKER_INLET= ( INLET, 288.15, 101327, 0.0, 1.0, 0.0)
MARKER_OUTLET= ( OUTLET, 101327)
MARKER_PERIODIC= ( SIDE_1, SIDE_2, 0.0, 0.0, -650.0, 0.0, 120.0, 0.0, 0.0, 0.0, 0.0 )
% ------------------------ SURFACES IDENTIFICATION ----------------------------%
MARKER_PLOTTING= ( BLADE )
MARKER_MONITORING= ( BLADE )
%% ------------------------- GRID ADAPTATION STRATEGY --------------------------%
% ----------------------- DYNAMIC MESH DEFINITION -----------------------------%
GRID_MOVEMENT= ROTATING_FRAME
MACH_MOTION= 0.3456
MOTION_ORIGIN= 0.0 0.0 -650.0
ROTATION_RATE= 0.0, 62.44, 0.0
% ------------- COMMON PARAMETERS DEFINING THE NUMERICAL METHOD ---------------%
NUM_METHOD_GRAD= WEIGHTED_LEAST_SQUARES
CFL_NUMBER= 1.0
CFL_ADAPT= NO
CFL_ADAPT_PARAM= ( 0.1, 1.2, 10.0, 1000.0)
RK_ALPHA_COEFF= ( 0.66667, 0.66667, 1.000000 )
% ------------------------ LINEAR SOLVER DEFINITION ---------------------------%
LINEAR_SOLVER= FGMRES
LINEAR_SOLVER_PREC= ILU
LINEAR_SOLVER_ERROR= 1E-4
LINEAR_SOLVER_ITER= 4.0
% ----------------------- SLOPE LIMITER DEFINITION ----------------------------%
VENKAT_LIMITER_COEFF= 0.05
LIMITER_ITER= 999999
% -------------------- FLOW NUMERICAL METHOD DEFINITION -----------------------%
CONV_NUM_METHOD_FLOW= JST
MUSCL_FLOW= YES
ENTROPY_FIX_COEFF= 0.001
JST_SENSOR_COEFF= ( 0.5, 0.02 )
SLOPE_LIMITER_FLOW= VENKATAKRISHNAN
TIME_DISCRE_FLOW= EULER_IMPLICIT
% --------------------------- SOLVER CONTROLS --------------------------%
%convergeance criteria
ITER= 999999
CONV_RESIDUAL_MINVAL= -9
CONV_STARTITER= 10
CONV_CAUCHY_ELEMS= 100
CONV_CAUCHY_EPS= 1E-6
CONV_FIELD= DRAG
WINDOW_CAUCHY_CRIT = YES
CONV_WINDOW_FIELD = (TAVG_DRAG, TAVG_LIFT)
CONV_WINDOW_STARTITER = 0
CONV_WINDOW_CAUCHY_EPS = 1E-3
CONV_WINDOW_CAUCHY_ELEMS = 10
% ------------------------- INPUT/OUTPUT INFORMATION --------------------------%
MESH_FILENAME= NACA_0012_Base_Mesh.su2
MESH_FORMAT= SU2
MESH_OUT_FILENAME= NACA_0012_out.SU2
SOLUTION_FILENAME= restart_flow.dat
SOLUTION_ADJ_FILENAME= solution_adj.dat
TABULAR_FORMAT= CSV
OUTPUT_FILES= (PARAVIEW, SURFACE_PARAVIEW, RESTART)
CONV_FILENAME= history
RESTART_FILENAME= restart_flow.dat
RESTART_ADJ_FILENAME= restart_adj.dat
VOLUME_FILENAME= flow
VOLUME_ADJ_FILENAME= adjoint
VALUE_OBJFUNC_FILENAME= of_eval.dat
GRAD_OBJFUNC_FILENAME= of_grad.dat
SURFACE_FILENAME= surface_flow
SURFACE_ADJ_FILENAME= surface_adjoint
OUTPUT_WRT_FREQ= 100
WRT_FORCES_BREAKDOWN = YES
HISTORY_OUTPUT = (ITER, RMS_RES, AERO_COEFF)
Old   March 2, 2023, 17:56
bigfoot
bigfootedrockmidget is on a distinguished road
Have you made sure to deselect "save all points" when saving the su2 file?
After saving, have you checked that the su2 file contains points, connectivities and markers? This is a gmsh problem, not an su2 problem.
bigfootedrockmidget is offline   Reply With Quote
Old   March 3, 2023, 10:53
Kamran
yeah, i did bro, I think I managed to resolve it. I think the issue was that the sides of the aerofoil were created using splines when the step file I created was merged and there was a bunch of repeated points, I think I managed to resolve it by defining the lines of the aerofoil as physical curves
Old   May 25, 2023, 05:15
Default NPOINT mismatch
Giacomo
bene_ is on a distinguished road
Hi everyone,
I've been struggling with GMSH for the last 3 days. I keep getting the same error
"Error in "void CPhysicalGeometry:istributeColoring(const CConfig*, CGeometry*)":
Mismatch between NPOIN and number of points listed in mesh file.
Please check the mesh file for correctness.
even when I try to mesh the simplest possible geometry and run it in Su2. I have made several attempts, even trying to define the curves as physical surfaces, but no luck.
I'm hoping someone can help. Thanks in advance.
I've attached the .geo and .su2 files.
bene_ is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
