Home > Forums > Software User Forums > SU2
The iteration stops earlier than the set value.
Old   March 19, 2023, 00:22
Default The iteration stops earlier than the set value.
Zhang
Amber0922 is on a distinguished road
I set the iteration as 30000, but it stops earlier than the set value, and reports "Error in "void CSysSolve::ModGramSchmidt(int, std::vector<std::vector<double> >&, std::vector<CSysVector>&)": ".I want to know how to solve it and finish the whole iterations.
Amber0922 is offline   Reply With Quote
Old   March 19, 2023, 08:26
bigfoot
bigfootedrockmidget is on a distinguished road
Your simulation has most likely diverged, that is why it stopped. Can you show the last couple of lines of the screen output?
There are many reasons for this. Some things to check:
1. mesh quality
2. Setup of the physics models
3. Setup of boundary conditions and initial conditions
4. Setup of the numerical solver
If you share your mesh and configuration file so the problem can be reproduced, it will be easier to help you solve this issue.
bigfootedrockmidget is offline   Reply With Quote
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
set BC mass-flow-inlet via UDF and via GUI perform different result sawa25 FLUENT 1 February 25, 2015 01:51
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
