CFDinTwente |
March 26, 2024 15:37 |
--cpus-per-task using SU2 op HPC
Dear all,
I can't seem to use the full capacity of my node using slurm. I am using the batch file below but when checking the node with htop I see only 4 cores busy, while I was under the impression that I would see 4*9=36 nodes doing work. When going above the 36 nodes I get the misconfiguration error, so that seems to be the actual limit to me but I do not get why it is then idling on most cores. I hope you can give me some advice.
#!/bin/bash
#SBATCH -J mu_m16_hdef_v1 # job name, don't use spaces
#SBATCH --nodes=1 # number of nodes
#SBATCH --ntasks=4 # number of MPI ranks
#SBATCH --cpus-per-task=9 # number of threads per rank
#SBATCH --mem-per-cpu=1GB # amount of memory per core
#SBATCH --threads-per-core=2 # number of threads per core
#SBATCH --time=48:00:00 # time limit hh:mm:ss
#SBATCH -p 50_procent_max_7_days # Partition
#SBATCH -o out.log # output log file
#SBATCH -e err.log
# module to use
module load gcc/9.4.0
module load intel/oneapi/2023.1.0
source setvars.sh
# log hostname
pwd; hostname; date
# executable
SU2=/home/SU2_software/bin/SU2_CFD
# config file
cfgFile=run.cfg
# set environment variables
NTHREADS=$SLURM_CPUS_PER_TASK
export OMP_NUM_THREADS=$NTHREADS
export UCX_TLS=ud,sm,self
# display configuration
echo "Number of nodes used : "$SLURM_NNODES
echo "Number of MPI ranks : "$SLURM_NTASKS
echo "Number of threads : "$SLURM_CPUS_PER_TASK
echo "Number of MPI ranks per node: "$SLURM_TASKS_PER_NODE
echo "Number of threads per core : "$SLURM_THREADS_PER_CORE
echo "Name of nodes used : "$SLURM_JOB_NODELIST
srun $SU2 $cfgFile
